Here's a little test for everyone interested.
I've put a piece of music in FLAC on three different players and recorded the players' headphone outputs with Sound Forge 8.0, with a standard 16 Ohm load attached. My sound card is an Echo AudioFire, it's more precise and sensitive than these MP3 players, so the recording quality should be sufficient. Well, everyone can decide that for themselves when they listen to the tracks. For that reason I've also included the original file that I ripped directly from the CD in this test, to make it more conclusive. The only modification I did to the files was normalizing them to the same level (matching the player with the lowest recorded output).
The audio track was ripped from CD by me, using EAC in secure mode, Test&Copy, and AccurateRip. It's a 100% perfect rip.
So here are the four candidates, with a little description on what
RMAA shows about those players - but of course you better listen for yourself instead of trusting graphs. Specs like SNR, THD, IMD don't really matter for these players, the differences should be inaudible and negligible.
- Hifiman HM-801: average sound quality, rolled off treble, mediocre channel separation
- Cowon V5: average sound quality, rolled off bass, better channel separation
- Sansa Clip+: average sound quality, linear frequency response, mediocre channel separation
- Original FLAC: exactly what is to be heard on the original CD
Can you hear the differences? Also, always keep in mind that one of the four tracks is the original.
Here you can download the
test tracks. In that folder is also a password protected RAR archive with the solution key to the files. I will give out the password in a few days, after some people have listened to the files and posted their results.
I recommend
Foobar2000's
ABX plugin for a comfortable way to test these tracks. But of course any other method works as well. Happy listening!
