odigg
- Apr 1, 2008
As I can see the frequency response is not flat, but the roll-off seems to be not so obvious until 10 kHz. I listen to a lot of Metal music and I could not think of one instrument that reaches that high anyway (other than subharmonics maybe). Aren't those frequencies cut off by mp3 encoding anway? To me it seems like we are not taking into account how the Hifiman actually sounds. I mean the graph is all nice and it is obviously not a flat frequency response but so what? Do you actually listen to music at those frequencies?
Let me present this from a different point of view.
Let's say you go to the store and purchase an expensive product with a feature called X. When you get home and play with the device you find that feature X does not work properly. You go back to the store and a store employee says "Well most people don't use feature X so who cares if it works properly or works at all. It's not like people will notice it."
Would you then say "Oh, I guess that makes sense. I'll just keep it."
According to the Hifiman specs it supports 96khz files. Yet, based on these graphs, it cannot fully support that feature. The measurements show it cannot support the claim that it can accurately (according to industry specifications) reproduce the standard frequencies reproduced on a standard CD or FLAC file.
If you cannot hear it, or if some people prefer the treble rolloff, does that mean everything is fine with the player? What about the people that can hear 20khz? What about the people who can successfully ABX the files dfkt has provided?
Let me be honest, if this was a $50 mp3 player I wouldn't even post in this thread. But this is an $800 player that IMHO, should be held to the highest standards. That includes (as I've said many times before) industry standard measurements and specifications.
As for where the EQ should be, let's remember that both the professional, home, and audiophile audio industry have striven to create products that are sonically transparent. Products like the HD800 have been praised for the transparency. The statement "I'm listening to the music, not eqiupment" is used as a blessing on the best eqiupment.
The measurements RMAA provides are one indicator of just how "transparent" a piece of gear is. A non-flat FR is an indicator that "transparency" is not where it should be.
Perhaps you don't like a flat FR. Myself, I find myself favoring headphones with a boosted bass or EQing the bass when using speakers or headphones that are designed around neutrality. But that's my choice. And I can do it for free with a software EQ or with changing my headphones or speakers based on measurements. When my other eqiupment measures flat I don't have to think about how this eqiupment is deliberately changing the sound.
And as a last point - I don't think I'm going to post in this thread any more. I've made my point (repeatedly) and I'm sticking to it. I have little to add beyond this.
