As far as gross misinformation, I’ll let the measurements and opinion stated stand on their own as it’s more than what you have offered. If you have counter points please feel free to share them and if you call stating opinion trolling you should look at some of the outright defenders posts first as they are outright insults …
I was referring to your completely wrong information about the PCM1704 and you know it. Also, if you had taken the time to read my post, you'll note that my criticism is of the conclusions made, which are misleading. You both need to read up about how digital audio works. Google "digital slow roll off filter" for a wealth of links explaining them. A snipped from the very first link I found:
A slow roll-off anti-imaging filter also has another consequence. Because of its slowroll-off rate, its impulse response exhibits less ringing and time smearing as compared
to a conventional sharp oversampled anti-imaging filter. Fourier analysis shows that thetime resolution and bandwidth of all filters are inversely related. A slow roll-off filter
allows more high frequency energy through compared to a fast roll-off filter. Therefore,the slow roll-off filter has better time resolution, or equivalently, less time smearing.
However, a big curve on a magnified graph certainly looks more impressive when you set out to trash someone's gear, as well as every high-end DAC out there. However, your contempt for the people here and subsequent negative bias is quite clear from this post by dkft on your forum, in reply to a bunch of posts trashing the 801 because of its size:
Yeh, I almost died laughing when I saw the photos of people using that ridiculous thing with the "balanced" RSA amp, or the nice looking, portable Pico Slim...
Exactly and I just wanted to express my support for this test and it has shown that although the Hifiman sounds good to me a generalized word like "hifi" should not be associated with it due to the roll-off, as I believe that the general consus on hifi is the reproduction of the music as closely to the original as possible. And I suppose we see clearly now that this is not the case. So the hifiman is best described as "musical" instead off staying it sounds "hifi", no? BTW: I also have to express my gratitude for choosing this thread title as it does not imply some off the bashing that has been written here. After all it is a product that does receive a huge amount of customers from people reading on this forum, so I'm glad that we can discuss the results of the test in an objective manner as we are. I know some threads where hype/bashing makes it extremely hard to come to a decision and I end up choosing not to buy a product at all because I'm more confused after reading the thread then before and I believe that this thread will clearify things for possible customers.
See what I posted above about filters. The musicality of PCM1704-based DACs has to do with their lack of a "digital" sound, that is, instruments and vocals sound real, and not like a poor, digital reproduction.
Nankai: I will only repeat what I already said: Anyone criticizing my method of testing should simply point out which one's the original file from CD, which one isn't recorded over my sound card. There's no need to bring fancy Wadia players and such into the equation, since this thread is not about them. My premise is very simple: there are four files - which one is which? Is there a difference, compared to the Hifiman, Clip, Cowon? Is the difference huge or small? Is something "better" or "worse" sounding for oneself, subjectively?
I only said that the Hifiman has less treble and sounds a bit more veiled than the other players. Statements I made about the Clip are blown way out of proportion. It's an average player with it's share of flaws, just like other players. It's just what I use the most, so I happen to compare it more than any of my other players.
I am criticising your conclusions, such as about the treble. You said yourself on your own forum,
"Sad that people can't accept facts." You need to learn to accept some facts about how digital audio works, because while I applaud you for doing measurements, your understanding of the results you get is grossly lacking and, worse still, you are spreading your ignorance as facts.
If anyone wants to do a simple test to understand why the slow roll-off filter would have essentially zero effect when listening, find that "Measure your ears' frequency response" page and listen for yourself how hard it is to tell the difference in volume of high frequencies.
