wink
His amps are made out of recycled beer cans
and his source from tomatos.
- Apr 13, 2009
Bad move, right there.......
Fang is most likely biased since he wants to sell his expensive EF-1000 amplifier with the HE-1000.
It's better if someone who is independent does a proper test.
Does anyone have a frequency response graph for the HE1K? Perhaps a beta tester with access to some testing equipment?
The EF-1000 is an hybrid tube input, ss output design, which will deliver between 8-15 watts depending on the impedance of the headphone when used as a headphone amp, and 50 watts class A or 150 watts class A/B when driving speakers. it uses 6922 tubes. 6 of them. it will be se and balanced. so no it is not gonna be cheap.
I don't care if the he-1000's sound as good as a Victoria's Secret model climaxing - if they don't show perfect results on a frequency response graph I'm not buying them!
They are not JPS Labs. A follow-up to the below and a flagship costing almost 3x the previous one, would be very embarrassing otherwise:
http://www.innerfidelity.com/images/HiFiMANHE6.pdf
I have confidence in Hifiman. But since you ask for it, I would want both a frequency response chart AND a THD one.
