- Mar 20, 2010
I know some of you guys rubbed off the Hifiman HE-400 logo on the side
What'd you did you guys do to get it off?
Thumbnail. Both the logos and L/R marker rub off with very little force of the nail.
Everybody says the drop in upper mids takes away from vocals. I don't think they do. I compared vs the LCD2 and the LCD2 isn't some magical deity in comparison when it comes to vocals.
Dropping the HE-400's mid-upper treble will take away some of the sibilance found in its vocals though.
How many revs. are there on this headphone? I'm getting Rev. 2 today, is that the best one?
Ok, thanks!Yes, that is the latest.
[COLOR=A9A9A9]it is often called Rev 4, but it is basically the Rev 2, you can find a little description in the OP[/COLOR]
Guess we'll just have to agree to disagree.
The distance that the J$s puts the ears away from the drivers accentuates treble and bass relative to midrange, it's not even a matter of damping. Midrange becomes more prominent (relative to treble and bass) when your ears are closer to the drivers, try it, it is an apparent effect even sans earpads.
The "upper mids" drop of the HE-400 is NOT were the critical human voice frequencies are. There was an interesting web link I had explored earlier breaking up the components of voice. The spoiler is that the HE-400 is generally flat or slightly boosted in critical vocal areas.
Sibiliance has not been a problem to my ears - and trust me, I hate sibiliance. What I suspect some people are not realizing is that the HE-400 are extremely revealing headphones - you will generally hear what was recorded. I have listened to tracks that made the HEs sound "warm", and tracks that come across a little "cold".
Its very important in audio that, when you think you have found a problem, you put the listening in context. By that I mean, if sibilance isn't a problem 90% of the time, than your song was likely the problem.
Now, I don't want to sound like an HE-400 apologist, because they are not perfect. But voices, in conclusion, sound great and super natural to me (if a little forward at times).
I couldn't agree more about the mid range coming up with eardrums closer to the headphone diaphragm. I had G-cushion pads on my Grado RS-1s, and when I used them after not hearing them for a few months, they sounded entirely different than I remembered. I took the large cushions off and installed "flats". The mid-range jumped out! They sounded much better.
I'm receiving the HE-400s next Wednesday. I played around with the Foobar 2000 equalizer. Does anyone do this for each headset they use? Here's what I came up with:
For this HE 400 response graph:
Does this look correct, or do I need changes? I'll probably leave the equalizer "flat", but I like to try different things.
No, they are not calibrated to be perfectly flat, otherwise his 'ideal' graphs would be completely flat lines. If you've read through any of his articles on measurements, you'd see that his ideal graphs are flat to 1-2khz then have a dip around 2-8khz with a little spike centered around 10khz. I don't have the article on hand anymore, but I remember his saying that the compensation (provided by the manufacturer of the dummy head) is what he uses, and he admits it's not the most accurate.
On the other hand, if his raw graphs were supposed to be what represents flat to our ears, then HE-400 would be among the most flat headphones out there, which clearly isn't the case.
I would prefer to have an HRTF calibration curve for the special conditions of two speakers placed 30 degree of axis as that is what the headphones are trying to simulate, but no such calibration exists.
