Hi everyone,
To begin with, the HE-400's are the first pair of audiophile-grade headphones I've ever owned, and this is my very first post on head-fi!
While I am loving the HE-400's overall, I have some concerns I'd like to discuss with all of you. I'll start by saying I have the revision 2 drivers (white) and the faux leather earpads. I listen mostly to flacs and use a sound card (Xonar DX) and a dinky amp (fiio e6). Even with the revision 2 drivers, I find these headphones can, at times, be distractingly sibilant and shrill. This is especially the case when a female voice is swelling or the symbols are crashing away.
My other question is about the stage - it sometimes sounds as if I'm standing at one end of a giant tunnel, and the band is playing 300 yards away, way down at the other end. By the time the sound reaches me, I've lost a little bit of the detail and everything sounds tinny (and even muffled, at times).
Lastly, with certain songs I feel like the sound lacks body.
Will burn-in address these issues, or does the sound of the HE-400 pretty much stay the same? Is three days of pink noise the answer?
Will a good amp fix these issues? Part of the reason I bought the HE-400's was because they don't require a super-high-end amp to work well. If, however, an amp will tone down the highs and give the sound a little more body, and maybe even fix the stage problems, I would be willing to invest around $300, but would like to stay lower. Can anyone recommend a good, portable (USB), "dark" amp or amp/dac combo that would take care of my problem?
Do the velour pads really make that big of a difference?
Should I just throw in the towel and try the HD600?
I WANT to love these headphones unconditionally. Sometimes when I'm listening to them I get so wrapped up in the sound that I can't imagine returning them. I find that vocals sound particularly crisp and colorful on the HE-400's (unless the singer gets too high up there, and that harsh sibilance comes into play). The bass is detailed and tight but still somehow packs a punch. If only I didn't cringe so often while listening to them...
Thanks guys!
