The he400 are essentially a dark sounding headphone with a treble spike that can be eqd out leaving them sounding detailed, dynamic and ace!
As an example, what frequencies do you EQ, and by how much?
Thanks
Thanks
Look through the images and you will see a bunch of eqs.
i have the He 400 and i dont understand the general need for equalizing them.... I had this repulsion for the highs when i had them paired with some incompatible amp ....Now i had absolutely no fatiguing high...best regards
Is there a way to search for images in a thread?
Thanks
I don't have a lot of experience, but I don't care for a bright sound, so maybe the HE400 is not for me then. But I do want something that will go very low.
Help me understand how the 400 can be V shaped and neutral? I thought V shaped meant emphasized bass and emphasized treble (or recessed mids I guess would mean the same thing), and neutral meant a relatively flat line, with nothing emphasized to anything else. Am I not understanding this correctly?
Thanks again.
What EQ are you guys using to keep the treble down? I searched on this thread and they are all electric-Q files. I have a mac so I can't use footer with electri-q.
Can you guys pot the frequencies dB to cut?
Thanks again.
As a compliment to the HE-400 and HD598, which 6xx headphone would do best?
HD600 or HD650?
Neither?![]()
