mohsin9221
Can you specify which dac chip is used. Any specific model name.
https://www.cirrus.com/products/cs42l42/
I can't make my dongle work on my galaxy s8, can i get some help?
Hi, I was just looking for a low price AMP DAC for my laptop and I found this page on google, thanks for this nice & informative review. I need to ask few things before I get this. I have a Dell laptop with Realtek ALC3234, do I have to remove/uninstall the driver to use Sonata HD or does this device work with the Realtek? I have Kingston HyperX cloud core headset (don't use mic) and I just ordered KZ ZSN Pro earphones on Aliexpress and waiting for arrival. My use of this device will be purely for music and movies.
Thank you
Go to the developer options and mingle with the USB options there. Or try to reset the developer options to default and then try to turn on and/or off the USB options there while connecting and disconnecting the Sonata. Usually, if the hardware is OK, it all comes down to the way the USB devices are automatically detected by the smartphone. Maybe your USB is configured in a way to only accept charging and data...
Thx for your input, but I've tried messing up with the dev options, there aren't too much to mess in the s8 menu anyway. And I've goten nothing from it. I have also installed all of the firmwares more than once and got no result. In my computer it works plug'nplay in all of the firmwares.
I will try on my father's xiaomi mi5 that night and see if it works. The S8 simply doesn't recognize. If i use the sonata on the USB adapter for pc jacked into the "USB-USB type-c" converter that comes with the s8 the sonata isn't recognized as well, it keeps popping up "device connected"-"device disconected" every second. I think it has to do with my smartphone.
@peter123 your s8 are on android oreo or in android pie?
I'm using Note8 and have the same issue after upgrading to Android Pie 9. It keeps saying Disconnected and Connected non stop until i unplug the dac. Tried USB OTG with my Dragonfly Red and still have this issue, seems like this caused by the Android OS
It's not a pie issue. Works on my 1+ 6t on pie. It sucks that android can be so hit and miss.
Do you think Factory Reset will fix this ?
