Hidizs Sonata HD DAC cable - new tiny and mighty DAC&AMP
May 9, 2019 at 9:21 AM Post #496 of 862
Do you think Factory Reset will fix this ?
I am thinking in a clean factory reset by odin to try to solve the problem as well.
The hidiz works fine on my father's mi5.
May 9, 2019 at 10:02 AM Post #497 of 862
Don't forget to try a soft reset... :wink:
Tested the Hidizs Sonata on my wife's brand new Honor View 20. Works perfectly. So, one more smartphone to the good list! Using Android 9 with Magic UI over EMUI.
May 10, 2019 at 10:03 AM Post #499 of 862
Is it better than Realtek HD Audio? I have Realtek ALC3234 in my laptop.
I have Realtek codec in my laptop and the HD2 is an improvement for sure.
May 20, 2019 at 8:08 AM Post #501 of 862
Hi
Has anyone got this to work on any of the oneplus. Phones. Oneplus 6 t or oneplus 6 .
Works perfectly fine with my 6T. I also use USB Audio Player Pro with it.
May 22, 2019 at 9:41 AM Post #505 of 862
May 22, 2019 at 4:30 PM Post #507 of 862
Has anyone used This app
Poweramp v3 for 24 bit flac
On oneplus phone with hidizs sonta dac
For best results you'll want to use the Hidizs, or any USB DAC with USB Audio Player Pro from the play store. You'll get the full volume, and the option for bit perfect.
May 22, 2019 at 4:41 PM Post #508 of 862
In alternative, the Hiby app also does that for free.
May 23, 2019 at 10:03 AM Post #510 of 862
