Jun 10, 2023 at 1:54 PM Post #601 of 2,374
BTW, is the battery of this device is really that bad? How long will it last for class AB, high gain, volume 50, 4.4 balanced?
I just returned my Hiby R6 III, thinking of buying this instead?
I have old ShanlingM6 which used AK chip and i like the sounds. Hiby R6 III is ES Chip. Hiby R6 Pro2 is AK chip, hence i want to stick with that.
Thanks.
Jun 10, 2023 at 7:58 PM Post #603 of 2,374
I get about 6ish hours with this configuration described above (using FLAC/WAV, and with screen off, no BT/streaming/apps in use). Do bear in mind that battery life is expected to degrade with repeated charges over time, and the above tests are from a new DAP.
I suppose if you use MP3s it might consume less battery. The class A amp is the one that burns more battery than the AB one too.
This DAP has really excellent sound, it can compete in sonic fidelity with some of the Sony higher end DAPs like the WM1A for example, just that the Sony ones probably can hit near 30 hours battery life.
Jun 10, 2023 at 8:11 PM Post #604 of 2,374
Anyone found a third party case ?
The stock case is nice and slim, but unintuitive. The buttons are flat so it’s hard to know where’s what and that makes it practically unusable.
Jun 11, 2023 at 4:23 AM Post #606 of 2,374
You can find a crystal clear one on aliexpress
Jun 11, 2023 at 4:26 AM Post #607 of 2,374
I notice I can change gain during the first seconds of LO mode and then clicking on gain changes nothing. I suppose this is linked with the automatic LO like described on the manual...
Do yours react like this in LO mode too ? I'm talking about what I describe for the gain option. I'm little worried...is it normal or not ?
Jun 11, 2023 at 9:46 AM Post #608 of 2,374
Thank you. I’m not a fan of TPU cases. The custom made leather cases on Aliexpress also look ugly.
I hope someone will make a slim leather case with etched buttons. Until then I’ll use the original.
Regarding your LO issue, I can check this later when I get home.
Jun 11, 2023 at 11:02 AM Post #609 of 2,374
@YanaMJ I checked the LO + Gain.
Seems like a Software bug. Gain only goes higher in LO mode Low -> Mid -> High. You cannot go lower until you unplug.
I’m wondering if it should even be possible to change gain in LO mode. Does it make sense ?
Jun 11, 2023 at 11:10 AM Post #610 of 2,374
Seems like a Software bug. Gain only goes higher in LO mode Low -> Mid -> High. You cannot go lower until you unplug and plug the LO again.
Same observations than me...so not a defectiv device but a strange behavior as well... Usely we can't change the gain with a true LO like on my R6 2020 for example. So I think the right gain for the LO is the one we obtain by clicking on gain.
Jun 11, 2023 at 11:20 PM Post #611 of 2,374
Today when I powered up the R6Pro II the screen had the Android “robot” laying on its back with it’s front pane open, a red triangle with an exclamation mark, and small text that said Invalid Command, or no valid command, or something like that… This happened three times, each time I would power down and then power back up successfully.
I am on latest firmware.
Anyone else seen this or have any suggestions?
Jun 12, 2023 at 12:22 AM Post #612 of 2,374
(Cross-post from the RS8 thread)
For the Neutron Music Player users on the RS8, R6Pro II, and R6 III (HiBy's Android 12 based DAPs) who are facing the issue that tapping the play button starts fast-forwarding with silence, instead of playing music.
(I already reported the issue to HiBy support. And they are working on it.)
I found a workaround.
Try turning OFF the "Audio Focus" under the Neutron settings -> Audio Hardware. Then the Neutron will play music much more stably.
Jun 12, 2023 at 1:33 AM Post #613 of 2,374
It did the same 2 times but I'm pretty sure it's because of the very sensitiv buttons. 1st when I was trying to get it out of the box (hit several buttons at the same time and second time, when I put it in the cover for the 1st time. It was very tight
Jun 12, 2023 at 1:43 AM Post #614 of 2,374
Thank you, that puts my mind at ease!
Yes, the buttons on the case have some issues to be sure, to the point that I am convinced if you simply look at it the wrong way buttons will toggle :wink:
I may try the hack posted earlier in this thread to remove the small plastic pieces in the case to make the buttons less sensitive.
Hopefully there will be third party cases available in the not too distant future!
Jun 12, 2023 at 2:07 AM Post #615 of 2,374
I try to loosen the case a little and it seems to work...
