Hi guys,
I had a couple of weeks to listen my Alu version of R6 and I would like to say that it is the best player I had, but ist still has issues.
First about positive. The sound is impressive. I compared it to FiiO X7ii and found the sound signature very close. May be R6 gives a bit wider stage and gives a bit more drive. I could not hear any disadvantage of high OI using Dunu 2002 with only 10Ohm Impedance.
Here are the first issues I faced:
1. USB DAC driver is impossible to install on Windows 10 64 bit. it gives always an
error .
2. Cannot make .wv files playing. The player either does not produce any sound showing incorrect frequency or gives some noise instead.
3. If I use the external Amp and then return to listening from headphone out the sound is distotrted and very low power. Works normal only after reboot. I read in this thread that this is the known issue and will be fixed in the next FW.
Please let me know how I can move with points 1 and 2.
