Originally Posted by lejaz /img/forum/go_quote.gif
unless the OP has the kind of money that goes into setting up a professional studio, his speakers and room would be as much, or more, of a compromise than the headphones.
This = yes. I have a very odd office/studio, on a converted porch with glass around a strange half of the room. I do not have the acoustic set up for near fields - and I'm confident I can find a headphone solution that can be 80% of my mixes/masters, with my other 5 sources being the other 20%. That's the plan, and I think it's possible.
Possibly the 701's are telling the truth about the bass and the other systems are way too boosted in the low end...or the truth may be somewhere in the middle.
This = yes as well - the part about the truth being somewhere in the middle. Most people listen to scooped setups for leisure - that's a fact. I could take 20 to 30 hz, up that by 8 db, and it will sound fine on these headphones - yet destroy ANY other stereo with a sub. Obviously, I have to mix with the idea of compromise across all systems, but these cans just won't do the trick when mixing for any system with a sub - unless I compensate with EQ prior, which I really don't want to do.
A lot of stuff mixed in pro studios sounds like crap, so there's something to be said for placing talent before gear anyway.
These days, I'd almost go as far to say that MOST of the pop/rock/metal out of pro studios sound like crap.
Still, I need that low end for the kick/bass presence. Mixing electronic on these headphones would probably be a bad idea as well.
Originally Posted by rhythmdevils /img/forum/go_quote.gif
don't get expensive amps to try to coax bass out of the 701. An amp will only improve it's character, which will always be tight, fast, light bass. If you want a different signature, get a different headphone. Only thing I can think of would be the HD600. But nothing will be as airy as the 701 while having any bass to speak of. If the airyness of the 701 is ok to sacrifice, or a good thing at all, only you can decide.
You took the words out of my mouth, and tomorrow my HD600's will be arriving. We'll see how round 2 goes. I've also switched out the Bithead for the Millet Starving Student. I'll get a dedicated DAC later that I know will JIVE with Sonar. The guys at headphone.com mentioned that they, "had never heard of Sonar". Sure it's not as popular as Cubase or Protools, but it's CAKEWALK. I was a bit shocked by that, but I digress.
Thank you all!
