Headphone CSD waterfall plots
Jan 24, 2012 at 1:22 PM Post #556 of 937
@purrin: Could you slap a 10-band-Eq with -4 dB at 8 kHz on that T1 and measure it again? I'm curious what the effect on the FR and resonances is. Hum... then again, I tested 2 equalizers in maybe not equal circumstances, but they sounded different with the same setting... mh. maybe I'm doing it wrong.
My measurement rig won't support a digital EQ. The two equalizers could have differing curve widths. This makes a huge difference. Try a parametric EQ where you can pick a frequency and curve Q.
Jan 24, 2012 at 2:50 PM Post #557 of 937
HE-500 and LCD2r2
I miss seeing new CSD plots every day.
Again, typical reminders:
  • These are not FR plots and shouldn't be taken as such.
  • Note scale of frequency, time, and floor.
  • Note floor is -36db which is deeper than most of my other graphs (of this style.)
  • Time is compressed - goes out to 4ms.
Impressive results with the HE500. Consistent decay with no ridges except a very low magnitude one on the left channel at 5k (resonances at 5k are typically benign.) I found the HE500 ever-so-slightly dark sounding from a vintage Sansui 5000 receiver and neutral with slight brightness from the ECBA (as I have it configured.) I tried listening for problem spots (ringing / resonances) and didn't hear any (although the 10k FR peak is notable.) I noted by ear a slight depression at 6-8k which isn't nearly as bad as measurements indicate. I suspect there is a measurement artifact at that spot (the CSD sort of confirms it.) [As an aside, the HE500 does not extend in the bass as well the LCD2r2, which can crank out low and sub bass at extreme volumes.]
Also very good results with LCD2r2. The short lived ridges at 6k and 7k are audible to me, but not too bad with the right setup. (I can live with them, but I'm almost sure RD will want to punch someone in the face.) Also very slight ringing on left channel at 12k. I didn't notice this at all (but have on other r2s I've heard.) This particular r2 had slightly less bass impact than the two best r2's I had heard. The shelf is not seen well because the roll-off actually starts around 300Hz (the graph starts at 500Hz) with this unit. Otherwise I'm not going to comment too much on the LCDr2 because it seems every other person and his sister has one on HF.
Both the LCD2r2 and HE-500 waterfalls mostly die at -36db by 1ms, with the HE-500's decay being a hair quicker toward the end.
Beyer T1 for comparison.
Jan 24, 2012 at 5:15 PM Post #558 of 937
HE-500 and LCD2r2
Thank you for these last measurements, I was waiting for quite some time for HE-500 CSD plots.
Please, your comments about the significant resonance around 700Hz in both channels for HE-500. Is it a measurement artefact or a real one?
If it is a real one, I suspect that resonances at frequencies below 1 KHz are probably not malignant, and they may contribute to the ‘creaminess’ in vocal, but may also  mask some details. I think I am hearing a resonance around 200Hz, also, with low Q, but that’s well below your graph’s frequency spectrum.
Again, many thanks for this and all your very valuable contribution!
Jan 24, 2012 at 5:36 PM Post #559 of 937
HE-500 and LCD2r2
Funny think is that this resonance is very apparent on Tyll’s data, not only in FR but, most importantly, on impulse response. It is evident for at least 2mSec. Maybe it is a resonance of the headphone cup and not of the transducer, so it is not apparent to your special measurement setup and not easily spoted by hearing?
Jan 24, 2012 at 6:53 PM Post #560 of 937
Usually stuff below 1-2k past 2ms are enclosure effects. I don't hear anything "off" at 700Hz.
Jan 25, 2012 at 7:44 AM Post #563 of 937
I am surprised you could get acoustic resonance down to 700Hz , maybe quarter wavelength for an open type headphone? That would still have to make it about 12 cm from the base of the earpad to the open end of the earcup, quite a big headphone! Felt and other porous materials effectively lower that resonance (make the earcup feel bigger in terms of acoustic waves propagating, but 700Hz still seems quite low...
Jan 26, 2012 at 2:54 PM Post #564 of 937
I am not an expert here, so please excuse me if I am missing something, but I do not believe that mechanical resonances are only made because of air standing waves in headphones. I cannot really understand the physics behind ortho operation, but every mechanical structure has some sort of resonance. In an ortho headphone there may be no resonances directly from the plastic membrane that produces the sound, but there are other potential sources, like the magnet structure, the ear cups, even the headband.
Anyway, I made an interesting experiment. I plug my HE-500 in my laptop mic input, using it like a huge microphone. In a quite room I singly hit in various places the ear cups and the metallic grill with a metal knife. I recorded the output with audacity (see attached image). I repeated this many times.
In every hit there is a residual resonance which fades away rather quickly. This resonance has a period of 136 samples. With 44100 samples per second, this makes a frequency of around 325Hz.
With this, rather crude, way I captured the vibrations of the plastic membrane of the ortho transducer when I hit the ear cup and the metallic grill. Of course this doesn’t necessarily mean that this same resonance exists when HE-500 is normaly used, as a headphone, but it is not unlikely.
So, a relative low frequency resonance probably exists. Maybe this is one of the reasons for the euphonic ‘creamy’ mids of HE-500.
Jan 27, 2012 at 12:40 AM Post #565 of 937
Good stuff purrin.  Thanks for all the time and effort you put into getting graphs for us!
Any chance at getting harmonic distortion graphs too?
*sigh* headroom's 500hz distortion graph annoys me a little.  I think it's just to impress the ppl who don't know what that means.  Either that or ppl are more serious about getting clean midbass than I thought
Jan 27, 2012 at 9:25 AM Post #568 of 937
Mh, sorry for deing so demanding purrin, but would it be possible to measure the T1 again, this time with an output impedance of 100 or 120 Ohm via a stick-inbetween-adapter or something? Beyer's own A1 has that output impedance, curious to see what effect it has on FR and the rest. This reminds me, what kind of source are you using for the measurements, anyway?
Jan 27, 2012 at 9:43 AM Post #569 of 937
I am not an expert here, so please excuse me if I am missing something, but ...
I am amazed by how clever some of you guys are! Somehow, people who have no background in measurements / acoustics have such ability to think outside the box! This verification by reciprocity is very neat!
Note that there may have been a misunderstanding: I was responding to purrin who mentionned it was probably an acoustic resonance (or I misread, need to read again), and that does not sound feasible to me at 700Hz based on small dimensions of the earcup.
I did not mean there was no resonance that could occur at 700Hz or lower. Indeed there could be headband mechanical resonance or driver / membrane mechanical resonance.
You'd need to make an FFT on your recording to confirm, but yeah, it would seem like there's a pretty sharp (undamped) resonance there. All I was saying is that I think it's not an acoustic standing wave in the earcup...
In your case, given you were hitting the headband and earcups and measuring the response through the transducer membrane by reciprocity, it's hard to tell if this is a driver or frame resonance. If I had to guess though, between earcup and headband, I'd clearly pick the headband for a 300Hz resonance...
If you can send me a text file with the time data you got (need the sampling rate or time & response vectors), I'll be happy to generate a frequency response and possibly a csd curve.
Cheers, arnaud
Jan 27, 2012 at 1:19 PM Post #570 of 937
Yeah - acoustic standing wave caused by the cavity would be impossible given the length of a 700Hz wave and the size of the cup. What I really meant what anything outside of the driver (doubtful it's driver ringing at these diaphragm sizes.) There seems to be some correlation with how the < 1.5/2kHz area looks like with certain earcup/headband designs, e.g. a lot of the Senn headphones look similar to each other (and cleaner than that of other manufacturers')
EDIT: I am wondering if it's the metal gimbal assembly. It is sort of shaped like a tuning fork. If I have time today, I'll run it on the RTA and tap on the gimbal.
