WilliamLeonhart
Has anyone here tried comparing the GR10e and the GR10? My only complaint about the original GR10 was that it lacks bass, has the vent hole on the GR10e solved this problem?
There are very litlle reviews about the GR10e, a reason could be they cost now 445 Euro in the EU. Today there are a lot of attractive IEM's in this price class, also customs and semi- customsHas anyone here tried comparing the GR10e and the GR10? My only complaint about the original GR10 was that it lacks bass, has the vent hole on the GR10e solved this problem?
The GR10 are exellent for some music but no all rounders by any means. The 3003 are great but in Germany still over 1000 Euro, that is way to expensive as other brands offer the same at a third or less if the price, but as always we are impressed by high priced statements. Sennheiser IE80 is still ar the top of the game even 4 years after their release, a classic already and there aren't to many of these, as models change quickly and new brands hit the market all the time.Right! I would consider checking out the Dunu range. Very interesting. I took the plunge and got myself some K3003's as they were a decent price new here in Switzerland, and they are just chalk and cheese compared to the GR10's. They make the Grado's sound a muddy mess, really! My point is, that many reviews pit the DUNU 2000's as directly comparable or better than the K3003's! At around 300 eurs that's no mean feat.
I thought I had found Nirvana when I got the GR10's but there are likely much better options available for less.
No doubt the Beyer/ AK will be good but I can't spend 1000 Euro on an in ear, so I stick to my IE80.if you are in germany, you have to try beyer x a&k [COLOR=141823]AK T8iE[/COLOR]
[COLOR=141823]those are sick..[/COLOR]
[COLOR=141823]for grado i think they shoud cut their price tag.. jvc fx series are better than gr10 with cheaper price.. [/COLOR]
I got good result with FiiO X1 and my iPhone 5s with Relisten player.I'm a Ponoplayer owner and have the Grado GR10 IEM's but the combination just doesn't rock my boat. There is to much voltage out (and hiss) from the Pono to be used with such high sensitivity IEM's. And as both can be described as somewhat lean sounding I would like to get some recommendations for DAP's that works great with the GR10. I'm not a big fan of the ESS Sabre Dacs, so old players are not a problem - but they need to be able to play WAV-files.
Yes most definitely.
Keep in mind though, that a perfect seal between the earbuds and your ear is necessary.
You have tested the GR 10e next to the GR 10 and notice an improved bass performance?
