Jmop
- Sep 17, 2014
I guess lush and soft would be the same haha.
For recordings that emphasize crash and ride cymbals and higher notes of strings esp. violins you will get sibilance as volume increases. Surprisingly, it still sounds correct (if you play instruments, you'll get it).
I don't really give much notice to sound stage. GR10/e has proportionate one not unlike others that give to much space but fails to fill it. And as I've said, the vocals is centered in your head with instruments permeating form there, like a singer.
Having owned both e and non e version, the perceived increase of bass of e version will pull your attention. "The e version gives up some of the mellowness but gives in return fast engaging sound," bass driven tracks give a more "uhmp" but still retains much of the mellowness. AFAICT, there is no unnatural drop off on the treble region.
The summary of GR10 is that aside of the lowest of the lows and the highest of the highs, everything is magic to me. Also, YMMV so give them a live audition, the broken in ones.
