goodvibes
- Dec 28, 2009
Not at a CanJam Monster booth.
It's really hard to compare IEMs to full size. The mids are detailed and not really forward. The bass isn't as punchy as 80s but extends better. They're more refined, extended and even once run in. They have plenty of prat but not the forward presentation or extra boogie of the 80s. More like the stax in presentation but smaller than the cans. That said, They're neutral enough that tips can swing them to a different sig. Hybrids bring up the mids and punches up the bass while still having enough top but I prefer the timbre with the stock tips over anything else I've tried.
Did my best. You'll need to do some listening. Sony hybrid tips. IE8s or SM3s don't sound like Grado cans so I don't really know what to tell you. It's rather personal expectations that need to be met and that can vary a lot. I can tell you that they'll reward a good source and not mask a bad one so that may play a larger roll in your satisfaction.
Not offended. Just gave a description without getting into too much opinion. I own them and they are my go to IEM. My cans are Stax LNS that I taylored the back for better solidity. My home kit is Naim 500 series. I still haven't heard the computer that matches dedicated audio kit as source, even with things like the Weiss int202 via ASIO or wasapi through my fav DAC which is the best I've heard for computer audio. I'm critical and it matters to me. What I was saying is that there comes a point with things this good that you really do just need to listen for yourself as you could speak to another with similar passion who prefers something else but to answer your questions.
The GR10 can be warm or not depending on source. They're fast, extended and revealing. Their soundstage depends on insertion. Shallow insertion gets you a large field. Deep insertion does not. They don't have recessed mids or phase issues that can sometimes enhance depth at the expense of the mids which for me is where it starts. They have a fabulous neutral but not analytical mid range that has great texture and harmonic structure when broken in which takes a while. To me, they have great dynamics as they can play loud and quiet at the same time with proper attack where you can differentiate the hit from sustain. Others will feel different as they're not unnaturally punchy. Shock and awe? Beats me but I can get goose bumps from them. They're neither as dry as most BAs nor as euphonic as most dynamics. I know either can work equally well but these are generalizations for descriptive purposes. Nothing can be more comfortable.
I find them quite the chameleon and is probably why you get some diversion of opinion on them. If you're looking for 'a sound' these are probably not for you unless you can achieve that with your source. Nothing is perfect but they're too close to right for that. Really, you need to find a broken in pair and see if you appreciate them as I do or not. It's obvious that not everyone will. That's great and they're not wrong for themselves but I keep going back to them regardless of what else I try. Of course, I haven't heard all the latest over $400 phones but I know of folks that like these over them and also the other way around. That part is up to you. I just wanted to let you know that they're definitely a contender, more comfy, as easy to use as an IEM can be and worth the effort for an audition. You shouldn't buy based on my opinion and I didn't want to wax lyrically about them just because I own them. Of what I've actually heard, the 2 IEMs in this range that I like the most are the Grado GR10 and the JH audio JH5 custom.
Vibes, I applaud your thoroughness, your willingness to help, and most impressively your even keeled attitude.
Rubbish!
[size=3em] “You can get more with a 2x4 and a kind word than just a kind word.” http://kindwordand2x4.blogspot.com/[/size]
