Halimj7
- Mar 2, 2012
Do you use any amps and what sound source do you use?
Great info to share! Thanks. Its comforting to consider the notion that you dont have to spend a fortune to find the "right" headphone.
[…]I recently purchased another pair of 80i's, (because I used to own 80i's but destroyed them by accident, and went straight to the Alessandro MS2i, but they weren't for me, and traded a friend for the 325is. I put some Vibro labs (classic) cups on the 80i's and (L) cushions, and I must say I am enjoying them very, very much, so much I havn't listened to my 325is's in about 2 weeks.[…]
Yes I have! and I love it... pop a couple to start and then live with them for a few days... evaluate, and pop more if needed...
what i'd really like to know is, how waterproof are the Vibro cups? Do i have to put them away instantly during rain, or can i still bike home from the train station(± 10 minutes)?
I'm thinking of getting myself a pair of 80's to replace my RS2's, as those shouldn't really be used as portables.
Is this the black stuff right on the back of the drivers you're talking about?
Would a combo of popping those + G-cush on the RS2(not RS2i) get me about the same level of bass as non modded with L-cush?
What will it do to my clarity?
They're waterproof down to 300'. Just kidding, they are coated with polyurethane, but I wouldn't recommend using them in the rain, plus the drivers would get wet. Other than that they are beautiful.
Si the black fabric behind the driver, use a ball point pen so you don't damage the driver... on my 225i it did not affect the clarity, just added some bottom end. as far as the rs2 goes I don't know, however you can then use a spent dryer sheet to undo the mod... although it is kinda difficult... so go slowly and live with the changes for awhile before going further...
the whole point of venting plus g-cush is so gain comfort and sound stage, while retaining bass... you will have to find the sweet spot, but yes you can end up with the same about of bass as your non modded l-cush setup.
Guys are the 325is great for low level listening?
If not what does? I want a headphone that is great for low level listening, not just good. In other words they sound almost as good at low levels than they do at high ear damaging levels. Thanks.
Yeah Tyll seems to be against any can that has other than a warm/treble polite signature. At least he's consistant.
Yes I heard the same thing regarding the GS1000i's and PS1000's. Actually either one of those, especially the later, is my dream headphone right now. 1600 dollars though is hard to swallow. What do you like about the PS500? Does it still, in your opinion, carry the Grado sound signature? Thanks.
