Rebel Chris
Orange County chopper...nice! This 'discussion' has been held a couple of times.
OmgThey can keep the cable just send out the headphones![]()
Upon reflection it seems to me possible that at least wooden Grados might be quite different from other headphones in terms of burn/break-in. I say this because I was raised around the theater and music world and worked there for a number of years (all behind the scenes, fortunately!) through the 1980s, the loudspeakers back then were largely made of wood, and they definitely developed over time (home equipment is, of course, more refined, and one did not see a lot of wood in it back then anyway.) It certainly makes ligical sense, wood being porous and a lot of vibration going through it. Obviously headphones aren't pumping out that much sound, but they aren't that big, so while the proportions may or may not be similar, the idea is. Plus glue, or at least the glue on these headphones, has to be somewhat malleable or nobody would ever be able to get the drivers out, it's not superglue. As far as the anecdotal element goes, I'm an immediate gratificatin junkie who just put a newish set of cans through the following, and there is absolutely a difference. Should you wish to try it, please note this is part one and if you look in the comments of the guy who posted it you will see the links to parts two and three. Being an immediate gratification junkie, I did not wait a full day to do each but I waited at least 4being an immediate gratification junkie, I did not wait a full day to do each but I waited at least 4 hours in between. I am also officially stating in writing that should you wish to try them it is entirely at your own risk and I accept no responsibility whatsoever. The guy also recommends not going through the cycle more than three times, so you bet I'm sticking with one. This doesn't mean I won't use other pink noise things though. Anyway, whether or not it works, I think my initial thoughts above are not as stupid as my usual ones:
Thought about it and ordered a Garage1217 Project Polaris to go alongside the Pro-Ject Pre Box S2 Edition '23. That way I can do either clean output or tubey distortion, without actually needing tubesMakes sense to me. I warn you, if you buy a Vali 3, it's only $150, but what it will cost you in productivity in the other areas of your life while you decide to listen to just one more track and okay one more track and gee let's just hear what this sounds like through it and then I'll get back to <task> etc. will be severe.
So i dunno what all the controversy is about.
https://www.head-fi.org/threads/different-perceptions-on-different-days.972358/
Yeah, i already said i also have this experience. But this is a changeable thing, "burn in" is not. Unless you're saying my listening experience is always bad on days i get a new headphone and always better than that 10 days later.
8 years working in a company, producing speakers and headphones and speaker-burn in does not exist. We tried, but could not find any trace of measurable change in speaker units after XXXX hours of break in.20 years in the audio industry repairing and selling speakers and headphones and burn in is real.
The “measurements” unfortunately will never tell the total tale. Proved it many a time with phono cartridges that all had almost identical traces. They never would sound the same. That was the reality to me and my fellow professionals in the business buddies. I always trust my ears for final comparisons and that is what worked for me. Over 40 years in retail audio at some of the best salons in NYC.8 years working in a company, producing speakers and headphones and speaker-burn in does not exist. We tried, but could not find any trace of measurable change in speaker units after XXXX hours of break in.
