lauthoerer
Your posts here and in the HP8 thread had a significant impact on my decisionHP8 MkII Signature is my favourite h/p/a !!!
Grado 325i with 325x drivers and new version of x-series cable (left, below).
Grado assured me that my 325’is’ would be repaired with ‘e’ series drivers. Instead they installed x-driver and x-cable. Im not too mad assuming 325x driver because the new x-cable they installed is much improved over my old 325x’s cable. Anyways, 325ix sounds awesome! Will compare against 325x later but presumably same sound assuming same driver. The drivers look identical at least. Grado did not inform me of repair details.
- 325’is’ repair though different than described by Grado turned out to be a good surprise for me and was swift at ~ 1week turn around time.
- RS2x repair is encroaching now on 2months. I dont miss it much because 325x preferable anyway, and the metal cupped Grados seem less susceptible to cable microphonics.
Will compare PS500e to 325x later.
Apparently I missed limited PS500x. well schiit
Wow, I want a repair just to have this new cable!
Looks like a lot less bulky and nicer.
80x has thinner cable? So did I likely get 80x drivers too?Maybe it's just the version of the 80x?
... but as long as the leather aroma persists, who cares?If you’re like many of us on this thread, your wallet will eventually have nothing but lint, dust balls and moths in it.
Actually, I’m hoping to retain the sound of the amp, but save 1k on the DAC unit I don’t actually need. The analog section should be pretty similar, no? When I got a separate tube amp (Cayin HA-6A), I consequently added a separate DAC (Nuprime DAC-9) and quite enjoy the added versatility the 100 step volume control of the DAC-9 gives me in combination with the HA-6A.
Now, the idea is to run all inputs (Vinyl & Streaming via Linn Selekt DSM and CD-9) into the DAC and from there to the Violectric V222 and an Icon Audio HP8 MK2 SE, replacing the HA-6A, and when the mood strikes to my Grado RA-1. Yeah, I know, lotsa levers being shifted here…
I have a V222 and a HP8 incoming next week. Absolute worst case scenario: they’re both worse than what I already got, then they’ll go again. If they do what I hope they do, I’ll be selling the two bigger amps and hopefully have „saved“ 2K from when I started…
The website says that SR80x has 4-conductor cable and SR325x has 8-conductor cable. I don’t know about the drivers though, Grado was always silent in that matter.I was only listening to unfamiliar albums so dont have subjective comparison. Will try comparing later.
^ measured without messing with any settings and trying to be as similar with positioning on coupler. Those are averaged curves but were very consistent anyway owing to snug fit and round interior.
Compare to L-pad peaks measured per Marv which pattern my velour bowl peaks (4-5kHz, 10-13kHz).:
https://www.superbestaudiofriends.o...-review-and-measurements-and-sr80x-too.13837/
Anyone know how to tell the physical difference between 80x and 325x drivers and cables? Or are drivers the same between 80x and 325x?
I emailed Grado and they said they would get back to me. Will update.
Lack of transparency is typical of most audiophile brands so Grado passes as acceptable.The website says that SR80x has 4-conductor cable and SR325x has 8-conductor cable. I don’t know about the drivers though, Grado was always silent in that matter.
