KnutS
Totally agree. I changed pads on mine to Beautiful Audio in wool. So comfy and the sound is just awesome.The RS2e with a Mojo 2 might be everything i'll ever need for listening to music.
Curious: What's the difference between the Ori and Beyer pads that fit with the Grado adapter? Thanks.
Does that soften the entire pad or just the surface? The abrasiveness doesn't bother me -- the pressure does.Have you tried washing the pads in washing powder and add fabric softener?
Try tonight and let the pads air dry
As previously mentioned they do reflect what is driving them. Although not hungry for power they definitely can scale up with amp that mates well.Interesting. Thanks. Maybe we have a clash of cultural terminology here: Is kitchen roll what we Yanks call "paper towels?" Sincere question.
I do love the "modability" of Grados. So easy to change their signature with dirt-cheap mods such as pad swaps, holes cut in pads, tape, paper towels, etc.
I still recommend wearing them a bit lower, so the top of the headphone does not pinch the top of your ear... works for me.Yes the whole pad.
If it’s pressure against your ears just bend the head band out a bit.
Just flex it .
Grasp the headband with both hands with the drivers pointing towards the floor.
Just bend the headband it’s only light weight sprung steel.
Never posted this thought before. Can't recall I've seen other posts. The G pads on my 325x, RS1x, and any other non-GS headphone, are just not meant to be. The ergonmics in terms of fit and comfort are "off" unless you get a GS headphone. IMHO. They are one of the most comfortable headphones I've ever had on the GS3000x. Can't say that with the 325x or RS1x, or for that matter the 80's or 60's.Jesus, these things are uncomfortable, though, even with the G "bowl" pads that sound so good. The tops of my ears are on fire after just 30 minutes or so.
I'll need to investigate ZMF Beyer pads and the Grado adapters as an option if these continue to grow on me at such a rapid rate. I have the ZMF pads for my HD 6XX, and they're sublime.
"Stretch" the headband out a little by pulling the cups away from each other and holding it for a few seconds. Repeat for a few reps. This helps reduce the clamp and thereby the pressure you're referring to.Does that soften the entire pad or just the surface? The abrasiveness doesn't bother me -- the pressure does.
Anyway, whatever gets you through the night!
Leo
It was slow all day yesterday and seems the same today.Double posted...
...is something going on with head-fi today?
I've been getting pop ups saying they were having "latency issues" with the host.It was slow all day yesterday and seems the same today.
Server having a brain fart ?
Fair enough. But I will say that I’ve just got the 3000x in for a demo and I’m beginning to believe that the driver positioning plays a part in what makes the two headphones (rs1x and 3000x) sound like they do. Please note this comment as I’ll come back to this when I round up my impressions in a future post.Never posted this thought before. Can't recall I've seen other posts. The G pads on my 325x, RS1x, and any other non-GS headphone, are just not meant to be. The ergonmics in terms of fit and comfort are "off" unless you get a GS headphone. IMHO. They are one of the most comfortable headphones I've ever had on the GS3000x. Can't say that with the 325x or RS1x, or for that matter the 80's or 60's.
Leo
