• The RS-1x continues home delivery of the musical goods! It does really get better over time / break-in. New / prospective owners, patience is indeed rewarded! Absolutely no regrets in my case.
• RS-1x after a little polish/wax at the headphone spa:
I am in total agreement, the RS-1x takes a good amount of time evolving into what it will be. Both the RS-2x and SR325x also come around and improve after at least 100 - 200 hrs.
To quote Jonathan c, “Patience is Indeed Rewarded”
Firstly, IMOHO, the G-pads don't sound good on every Grado can.
I own 6 pairs and the G only sounds good on half of them, I'm partial to the flat pads on the other half.
To me the cans I like to use with the G-pad are, SR325x, PS500, GS1000... Not with my others...
To me the G-pad adds to the sound stage, and gives the Grado's extra oomph, brings forward the vocals just a skosh, kind of like adding a bit of parmesan cheese to spaghetti.
With that said, they might not be to your liking, you will just have to test the waters and see for yourself.
I can't stand the flat or the L pads, anything that sits on my ears is just pain. So its G pads or nothing. The G pad replacement by Beautiful Audio look good too, bit more swish.
I wasn't too much of a fan of the GS1000e, but apparently the i is better?
Your last sentence all applies. In my opinion it has good bass also.
A lot of space. Easy to drive, a wee bit sensitive to to associated gear, scales well. Fun ride. YMMV
