asmoday
- Nov 10, 2011
.......these things retail for almost FIFTY GRAND!!!! LOL
How many did you order
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
i had great business dealing with Headphone.com(Headroom) as with many other people.
my first non-retail headphone purchase of my Grado SR80i's
they are a trusted site, as Grado's policy on online orders, warranty is not entitled if you buy from auction sites and various other sites, ebay, craigslist, Amazon is now on the list probably but email grado to check.
There are many flavors of the 325... here's a post that clears things up a bit
SR-325 in black plastic housing
SR-325i in golden aluminum
SR-325is in chrome/nickel
SR-325is in satin
Anyone know how easy/hard it is to get the ear cups out of the gimbals on the GS1ks? The gimbal is a full circle so it doesn't pull apart at all. Are the little pins on the side glued/screwed/other?
No idea, never thought to myself "let's rip apart my RS-1" lol (the GS1k uses the same metal gimbals). The Gilmore site didn't have any tips on removing the metal gimbals (they had it for the plastic ones). I'm guessing that Martin Custom Audio can probably do that for you, but beyond that I have no idea. Maybe get a flashlight out and look in the through the back - it was put together with the wood as one piece, so it can come apart. It's just a question of doing it without destroying the wood.![]()
If it's not a simple process I'll probably just leave it be and upgrade just the headband....would be nice to have some of those beautiful roadblacks and gimbals from MCA though!![]()
My understanding is that Amazon neither directly sells Grado, nor is an authorized dealer.
Can't you replace the locks without replacing the rods?
If I can get the rod caps off I probably could...hopefully someone has experience with them cause I'm not going to experiment lol
Where is you sense of adventure?![]()
Actually probably more adventurous than me with that much. I was going to replace the headband on my SR80i so I decided to see how hard it was to get the band out. When it came to twisting the plastic pieces they seemed a little more attached then the pressure I wanted to twist with. So I quit there and decided the stock headband was good enough.![]()
