Shane D
Well, the Beautiful Audio pads arrived! ...And they don't fit on the GS3000e. I'm gonna try for a bit longer, but this might be dead on arrival because Beautiful Audio did not test on larger Grados. Wow.
The Grado G-pad opening diameter is 52mm. I measured the Beautiful Audio G-pad opening diameter and it's 47mm.
When I first put them on my GH2's, it was a VERY tight fit. I actually broke a yoke putting them on. I had to work them around the wood quite a bit. But of course being hand made, there is probably some variance.
I have never owned genuine G-Cushs, but I do own two pairs of knock offs and they fit on quite easily.
My stock pads are the L-Cush.
