cirodts
- Jan 27, 2016
after a little over 100 hours of burn-in my rs2e finally has a suplime sound.
I'm really loving the 325e and just how fast it sounds for a dynamic driver. I think vocals sound better than any of my other headphones and the mids overall are just wonderful. The detail retrieval is top notch and the soundstage is quite a bit larger than I was expecting.
Now I can see why some people might not like the Grado sound because it can be quite intense and bright (at least with this headphone) but I wouldn't call it sibilant because it's a very clean and clear sound signature. If there is one drawback it is the bass which is very light but with a little EQ'ing you can get it to sound pretty decent but it does fall off quite sharp after 80Hz or so. For $300 this is a very good headphone that I'd put up against any other under $500 pair.
I don't think so, you could ask Grado if they can do that for you, but based on how those are glued I don't think they are intended to be replaced.but can these white stickers glued on the drivers be cleaned or replaced?
Forget about burn in. I thought the Hemp sounded better than my Hifiman Arya, LCD-X, HD660s the instant I pulled them out of the box and plugged them in.Anyone else notice that their Grado's sound stage opening up the longer you burn it in? I'm reaching a point where I like listening to the Hemp Grado over my Focal Elegia if the environment allows it (When it's quiet and no one else is in the room).
yo! share the s***, we need more hemp impression. or is it much easier to just say no?
