I just got the Schiit Asgard 3 and Bifrost 2. It's been a really great pairing with the GH4. I feel like the Grado has never sounded better as it really smooths things out and adds great bass detail. Anyone else have a similar experience with a good Amp/DAC?
For me it will have to the Gilmore design with vintage Grado that I have ... not sure about newer ones and believe it will still work. I found out about Gilmore when I goggle for PS1 which is nearest to my FG-1 and they were recommending then Gilmore headphone amps >15 yrs ago.
A usd499 Gilmore Lite mk2 was much better than more 3 times more expensive Questyle cma800r or latest 2 time more expensive Kinki THR.
It is only SE ended though and other have to be more expensive with their balanced option etc. which I will not need since I will nvr modify the grado fg-1 to balanced.
Cheers.
Richard
PS: Using the newly released Denafrips Terminator Plus .. the new "King" of R2R dac
yes. every transducers need juice to run, some need more juices to reach top performances so little bit good amp/dac could help getting more performances from time to time. whether it's worth the price or the effort, each to their own i guess
btw with last night topic about hobby and pricing. that's remind me of this movie
that's probably the vented holes, in e series, for prestige lines that's pretty normal. from reading other impressions usually there are 2 vented holes there.
for the driver color, not really sure, but i thought all prestige series have gray color driver, some probably have black gob. higher models painted with red and some models painted with blue most also have black gob
previous generations, non i and i-generation do not have vented holes on most of prestige models, especially sr60
for the color of the driver, i don't have much info about it, as far as i concern they all have gray color drivers, they just painted the gray color driver with red or blue(gs2000e/ps2000e perhaps) for color coded.
i forget the link of video where they painted the driver with red paint but hope this assembly video could help a bit
you can email grado to check is yours legit or not.
grado quality control is not that great, there are always cases of mixed things from time to time, so better to email grado
I purchased a set of G cushions for my RS2e...and they make that headphone sound like crap. The bass is gone and the highs are not as crisp and they sound distant.
Don't do it!!!!
I tried them with the SR60 and they also suck on that model. Luckily I bought them used.
Don't do it!!!!
