obobskivich
Mine are the black ones with black aluminum sleeves.
I'm wondering if the shell that the driver gets put into will affect the bass in some way. Since a lot of recent impressions have come from DIY headphones and not from the symphones product (since it's not available anymore), maybe there's greater variances with wood cups, wood or plastic sleeves, different cup depths, etc.
I hate to bring up measurements in this thread but none of the Magnum variations (V1, V2, V4 etc) that have been measured have overwhelming bass boom - except for one that was placed in some martin audio deep wood cups with extra aluminum spacers and then had comfy pads placed on the drivers. I get the feeling that the custom cups can have a big effect on the sound.
Yes, the ear-cups absolutely change the sound. Just like the driver box changes how a speaker will sound. This matters even for open headphones or speakers. My understanding/theory is that Grado cans are as close to a t-line as any headphone can get, and that's why the deep pipes make them bassier. Adding spacers will move you closer to something called a 1/4 wave, and that will eventually create a mud cannon with tons of distortion outside of it's passband (but if you use a big driver and a crossover/filter, you can make some killer subwoofers with this design!).
The drivers influence things too, of course (they can only be "so good" and no enclosure can make a driver better than it is, if that makes sense), but you can see major FR changes with adjustments or tweaks to the cups. If you want a really simple example, throw on your Grados (or any open headphone really), and put your hands over the vents.
I think purrin measured the SR-80 free-air and in it's housing as well, as a comparison. I'm not sure where the thread for that is, but you can probably find it if you're super curious. There was a difference though (I don't remember what exactly changed, but there was a demonstrable difference).
