Gr33nL34f
- Dec 5, 2011
what do you guys think about G-cush pads on a set of Ms1i's with 4 holes punched? im kind of wanting a bigger soundstage for opera music. currently using the L-cush pads.
I have been burning in my RS1i for 55-60 hours now, and i have noticed there is some distortion in the bass sometimes. Is that normal, and will it disappear?
No, it's not normal.
What are you playing through the headphones? Music - what kind? White noise, pink noise...?
What's your source? 320kb files, CD's...
And what equipment are you using - discrete components? A computer with a sound card? Other?
Yeah, ok. I use all kinds of music + pink noise to burn them in, and its one specific track with some double bass playing where there is a little distortion. It´s not the Grado rattle that some suggested.
Then there is this song. On ALL of my Grados it has Grattle-like sound when the drums kick in. And I'm pretty sure these cans don't suffer from the same problem as above.
The re-cabling of grados is possible. The possibilities/combos seem to be endless. I always make my own cables but in the end I'm not sure how much money i save when you consider a good soldering station and all the associated components. However i enjoy the process.
It sounds like Grado grattle.
Either some fluff on the driver. Blowing carefully over either side of the driver is said to move it.
Or I have heard something about a kink in the driver. I think it can be pushed out with some volume.
In both cases play some bassy music quite loud.
Or last resort, send them to Grado.
