james444
- Aug 25, 2004
James444 if you were faced with 300 to spend, would you go tm2 with included iems or bt20s plus the best iems money can buy for 250? One comment would be I assume the tm2 iem is water resistant whereas most iems may not be so that would be a factor. Thanks!
I don't have the BT20S yet, so this particular comparison will have to wait.
The included TM2 IEMs compete very well with the best I've heard. I have a selection of 35 test tracks to detect flaws in IEMs. The TM2 score a 32/35 right out of the box and a 35/35 with a minor damping mod, which is excellent.
Whether to go for the TM2 is imho less a question of sound quality than of intended use. For instance, they don't fit as tight and securely around my ears as the BT20, so I'm not sure I'd pick these for intense outdoor activity. For walking and hiking, I find them ok though.
Another aspect is nighttime / in-bed listening. I can comfortably do this with the BT20 and small IEMs, no problem. The TM2 would be low profile enough to be comfy in bed too. However, if you lie on the side with it, the touchpad may press against your ear and engage cue-play, which can be very annoying.
So, what I'm trying to say is, while I don't think you could do much better in terms of sound quality with the BT20S + $250 IEMs, you may probably be able to cover a wider range of use cases than with the TM2.
To follow up on the question "Fostex TM2 or BT20S plus the best $250 IEMs": I recently got my BT20S and a pre-production unit of the upcoming $250 JVC FDX1:
https://www.head-fi.org/threads/drop-jvc-ha-fdx1-dual-carbon-iem-available-in-the-us.912737/
These aren't water resistant, of course. But the FDX1 are among the best DD IEMs I know. And the BT20S + FDX1 combo sounds better than the stock TM2 imo. Not head and shoulders superior, but noticeably. Actually, it's the best sounding TWS configuration I have tried so far.
