vstolpner
i think thats an old rumour
Darn.... So is there anything semi confirmed at least for QCC51xx?
http://www.52audio.com/archives/13691.htmlDarn.... So is there anything semi confirmed at least for QCC51xx?
I think so. Still sound great though IMHO. There is also a IE800. Not sure if there is a difference in SQ though. Seems only a different look of the Earbuds. Both are 6hr battery.IE600, just SBC codec?
Anyone heard of either of these? Trying to find something in the size of Apple AirPods (case)....
T2 Touch
https://s.click.aliexpress.com/e/ch6y5EuY
Generic TWS 2000mah
https://s.click.aliexpress.com/e/bpQQ4uD6
T9 IP67
https://s.click.aliexpress.com/e/cAHJDBUM
I would probably check out that last one, just because cheapAlways been fascinated by that bullet shape form factor
Well, I was only able to pair them together once, then thereafter the left side refused to get out of pairing mode regardless of resetting, following all instructions multiple times, etc. They are now, regrettably, boxed and ready for return. I decided to keep my Creative Outlier Air Sport, as it is far less picky about pairing and has a more dynamic SQ than the did the Mifo. Plus 10 hours per charge is right at the top of the list as of now.You're really going to enjoy them! Mine are awesome, though I am enjoying the stronger base presence from my other dynamic models
Congrats. Those look decent. I really like the thin case in blue. Looking forward to hear more of the SQ sound.Another day, another delivery ... I received THESE today (18$ from AliX after 2$ coupon) and am very happy to report that they don't suck either
First I was laughing that the so often typo of True / Ture made it as a name onto the product package .... pairing was fairly easy, but I noticed that the 2 buds are identical and have no L/R marks .. so, listen to the voices in your head.
The other slightly weird thing is that they only came with one extra set of same size ear tips. Took me a while to find some other tips that fit my ear better AND let the buds still fit in the case. Those 'shafts' inside the ear tip on this one are pretty recessed. But with a good fit I am getting pretty nice sound. Not stellar, some passages sounded a bit harsh (but that could also have been my source files) ... will hopefully have some more time over the weekend and will write some more about my 5 odd new entries.
Oh, and 2600mAh power bank feature is nice, as long as you do not forget to bring that little dongle with you. The case in shape and size (and matte finish, though plastic, not metal, reminds me of the Mifo case)
Only way I could find is to use a needle and gently pry around.how do you clean the vents?
I also have a KZ ZST version of of BA/Dynamic combo that I like as well. Hopefully KZ will roll them out as well In TWS.
How is the fit? I am a bit weary about those and connection wise. The KZ wired bt ones are known to suck.I use the BT20 bluetooth modules from TRN to turn all my KZ IEMs into TWEI keep hearing KZ might work on their own model
As for your last two questions: no,I haven't yet discovered a difference.I have read it (awesome post btw!)
I'm currently using the mifo O5 professional, and while it's amazing in most aspects, it does lack in base a bit. The Anbes 359 are great, but don't have the level of clarity in looking for. So I guess I'm just wondering between the ones in your post, which ones would you recommend for having some base, very good separation and soundstage, and a relatively balanced sound signature?
Also, does the Qualcomm chip in the 1more set make a difference in connectivity? Or the aptx codec in sound quality?
