- Jun 4, 2014
That makes sense that I'd want to see the response at the SPL level of my normal listening volume. Perhaps this is where microphone quality comes into play. Maybe some are just more accurate than others? Or can compensation take care of this, and quality differences wouldn't be a factor due to the compensation? You already told me about expensive ones with low noise.
I wouldn't worry at this stage about mic noise or sensitivity. That's only important if you're measuring THD and THD isn't anywhere near as significant as FR.
to improve the accuracy of option 1, you can use your coupler to cobble together your iem and spl meter. just place the spl meter mic where you'll place your measurement mic.
That's a very interesting and thought-provoking suggestion - for a couple of reasons! It could be a good option for those that regularly take the mics out of their couplers (@McMadface's UMIk-1 mic seems to fit perfectly into these 711 couplers just via a push-fit). On the other hand...
I was recently told by Bob O'Neil (GRAS) that people can destroy their GRAS couplers by removing the mics. Liliang Hong (one of the Taobao sellers) told me their coupler/mic combos are "debugged" (I presume that is a loose translation of "calibrated") to a close tolerance before being shipped out, and hence don't need compensation files. I may be wrong, but I think the only way you could "debug" hardware like this is via the adhesive and how far you tighten the mic down the thread. I can vouch for the fact that with those generic Taobao couplers - unscrewing and then re-seating the mic does lead to different measurements. The seal and amount of volume determines the Q and resonance of the coupler. I know for sure you have to get that right or the coupler/mic measurements can be off by unexpectedly large amounts.
If you have a 711 coupler that came with its mic sealed in it, I'd be very cautious about removing the mic. @SilverEars and @Slater in particular - please don't try to remove your coupler mics - that would not have a happy ending.
