Fostex new RP headphones - T50RPmk3, T40RPmk3 and T20RPmk3
post-12834612
Post #1,471 of 1,983
walbum4262
For clamping force watch this movie by mrspeaker
https://m.youtube.com/watch?v=JHtaO5zRAAE
post-12834899
Post #1,472 of 1,983
c61746961
I covered all 8 of the vents in the ear cup with electrical tape, then I covered the back vent with another piece with an approx. 3mm notch in it. Deep bass is there in gobs, maybe too much. I may start peeling a couple pieces of tape off the ear cup slots to see the effect.
Yep, the sweet spot lies between 4 and 8 vents taped IMO depending on the listener.
I think I understand that covering the back vent reduces that mid bass hump (Ala the t40 graph from innerfidelity) and the ear cup prevents leakage and provides deeper bass. What would internal damping net me? Would that improve mid clarity? I'm thinking of doing newplast on the back of the baffle and some Silverstone foam on the inside back. Are there any potential downsides in doing those mods? Sorry full of questions and thanks in advance for any help!!
Absorbing materials at the bottom of the cups (being careful that they do not interfere with the back of the driver directly) will net a slight clarity increase in the midrange/treble. Downsides?, perhaps reducing the volume too much will mess with your baffle/outer cup venting scheme and you will have to redo this part.
Driver damping directly (with felt, micropore, fiberglass, cotton, latex foam pads, etc) will lower the bass dramatically and increase the energy past 2 KHz. The stock T50RP mk3 tuning is agreeable enough that only slight modding on the inside can be beneficial. I'd try aplying a bit of cotton or make up wedge foam only to the 'bottom' of the cup recesses to see if you discern any improvements. If you ever want more upper midrange presence, you can try placing a piece of tape over the driver 'hole' with a smaller hole in it.
Happy modding.
Reactions: nick n
post-12838611
Post #1,473 of 1,983
shoegazer72
I purchased a pair of t50rp mk3s but the stock pads are too small for my admittedly-largish ears and I find the treble a bit too forward/hot.
There's been numerous discussions concerning t50rp mk3 "pad rolling" in this thread and others - but is there a general recommendation for a set of replacement pads that offer better comfort while taming the treble a bit?
Apart from the treble, I find the frequency response of these to be just about perfect and would prefer not to change anything else.
post-12838666
Post #1,474 of 1,983
ProfFalkin
Website
goo.gl
I use the Shure 1540 pads, and love the comfort and sound. Available on Amazon.
https://amzn.com/B00HXAV0UY
post-12840250
Post #1,475 of 1,983
OSiRiSsk
It's interesting how one's experience differs.
I've found treble just the right amount with the stock pads, and hot with BrainWavz.
I have now put Beyerdynamic T5p stock pads on T50 rp.
expectations are high :-D
// Update after 2 hours:
My ears still aren't sore! The comfort with T5p pads is somewhere in between of the stock and brainwavz.
However, the sound quality is much much closer to the original - T5p pads are also shallow - but they have wider opening and much softer leather. Which means it produces similar sound with much higher comfort.
This seems like a final pads solution for me.
post-12841070
Post #1,476 of 1,983
Chembot3000
Out of curiosity, has anyone ever cut the filter off of the 1540s to expose the driver? I was thinking it might bring back the mids and highs, but $40 is $40, and am afraid I might ruin them
post-12841152
Post #1,477 of 1,983
AviP
See this post
post-12850524
Post #1,479 of 1,983
OSiRiSsk
I have cut the filling of the BrainWavz velour pads and put them on Fostex.
FInally - the comfort is superb, sound is almost back to the stock - deep rumbling bass, treble not sharp, mids velvety.
post-12859339
Post #1,480 of 1,983
SpiderNhan
Sunnyside, NY USA
Sunnyside, NY USA
  I have both and I totally agree with this. The Sines are quite a bit more (I paid $320 USD on sale though) but I think the T50RP Mk3 sounds better and is more comfortable, especially with the Brainwavz sheepskin pads for me personally . I use the Sine as a portable headphone and at work and use the T50RP at home. Great combination for me.
Have you done any other mods besides the sheepskin pads? And does it change the sound?
post-12861728
Post #1,481 of 1,983
antdroid
Seattle
Seattle
Website
www.audiodiscourse.com
Painted it, and used this moldable foam thing called "Floam" that I found at the store on the back of the cups under the driver. Not very scientific or anything.
post-12862963
Post #1,482 of 1,983
AMNovak
Bit of a shot in the dark, but I was wondering if anyone here has ever tried driving these with the Audioengine D1. I've been thinking of picking up a pair of these, but Zeos' stressing the need of a strong amp has kind of scared me off, and I'm not looking to upgrade my DAC/Amp quite yet.
post-12863050
Post #1,483 of 1,983
ProfFalkin
Website
goo.gl
what is your current dac/amp? I bet it would work. I use a Micca Origen+ with my RPs at work, and they power then just fine.
Reactions: shawnonrev
post-12863117
Post #1,485 of 1,983
ProfFalkin
Website
goo.gl
Sorry if I wasn't clear, I'm currently using the D1.
I had to look it up then do some fuzzy math, but at the rated 50ohms of the RPs you would be pushing about 80mw from the D1 to the headphones.  That's about twice what you'll get from the average cell phone. It's not ideal, but I think it will work.
If it's in the budget, I'd suggest http://schiit.com/products/magni-2.  $99 gets you 1W output.  $149 gets you 1.2W output and RCA outs if you need to connect external powered speakers.   Use the D1 as the DAC, connect the Magni to it via RCA, and then you're set.
