james444
- Aug 25, 2004
Heaven VII - "on the move" impressions:
- TL;DR: these are very good IEMs for commuting / travelling, but less suited for fast walking / running
- Excellent isolation (comparable to Shure / Westone) due to their long tapered housings and non-vented design
- Great ergonomics - very easy to put in and take out when you're on the go
- Cable is supple in warm temperatures, but tends to become stiffer and harder to wear over-ears below freezing point
- Absence of chin slider is annoying - build your own DIY slider
- Louder-than-average footfall noise, a result of high isolation and bone conduction via metal housings
- Seal tends to loosen during physical activity, due to high weight of the housings
- Lotsa looks from the female half of the population. If that makes you uneasy, be sure to get the non-glitz version.
