FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
222 223 224 225 226 227 228 229 230 231
233 234 235 236 237 238 239 240 241 242
  1. John1122
    I appreciate you taking the time to fix my post. as I am dyslexic I have to rely on these cheap text-to-speech programs that don't even compare to the ones on the computer.
    when I went to Best Buy, I heard the Dre Beats Pro-- I liked them for their Bass especially. But if there are any better headphones with more clarity and clean Bass, I'd really appreciate hearing about them. thank you
  2. John1122
    Which headphones would you recommend balanced or unbalanced I'm a newbie at this what if I bought an amp I have the c5 if but I will get the fiio a5 portable amp which headphones would you recommend, and which module do you recommend. I want something like the P7 but with a lot of bass.
  3. Brooko Contributor
    Hi John
    I assume you are looking for them for both portable and when you are at home. You like clarity - but you also want to be able to have additional bass if you need it. I'm not the best to advise re bass - but I know who is (call out for Chris @Hawaiibadboy )
    My thoughts would be to have a look at the Sennheiser HD630VB - reviews an be found here : https://www.head-fi.org/showcase/sennheiser-hd-630vb.20787/reviews
    Chris and I have both reviewed it. It has a variable bass dial - so you can dial in the amount of bass you prefer. It has very good clarity too. It comes with a short cable which has on-cable controls. They work perfectly with the X7ii, They aren't bass monsters, but they can get you really good combo of bass warmth/impact and clarity. If you wanted to further boost the bass, you could also go further using EQ.
    Because they are easy to drive, you can stay with the AM3A module on the X7ii which already provides a heap of power.
    They are my most used closed headphone and I can absolutely recommend them.
    Runding99 and Hawaiibadboy like this.
  4. Slim1970
    +1 on the HD630VB's with the FiiO X7 MKII. They work great with the AM3A. With it you don't need the A5 module at all. The AM3A module drives them very well. @John1122 another headphone I like with the X7 MKII is the B&W P9's. Super easy to drive, dynamic and clear and they will get you bass you are looking for especially since you like the P7's. They also work great with the AM3A module.
    Runding99 and Brooko like this.
  5. Hawaiibadboy Contributor
    Yeah, good rec. Adjustable bass for track to track adjust , good comfort good sound. I agree with Brooko and Slim :)
    mrmoto050, Runding99 and Brooko like this.
  6. Runding99
    Christmas appears to have come early with the firmware update.
    Thanks Fiio!
  7. Luke Redgen
    When I use the USB DAC mode on the X7-II it's really quiet, even at 120 volume on high gain it's just slightly loud on my super efficient Oppo PM-1s. Seems strange, the X5-III didn't have that problem, am I doing something wrong?
  8. Paulo Abreu
    Are you using X7-II USB DAC Driver ? http://x7pack.fiio.net/FiiO-USB-DAC-driver_EN-V4.11.0.zip
  9. russell finch
    Hello, apologies for the question , I have searched the thread and can't find the answer but can anyone confirm that 24/192 files play ok through the coax output? I thought I read somewhere there was a problem.
  10. Paulo Abreu
    Hi, 24/192 works fine thru coaxial, no problems at all.
    Regards
  11. howdy
    I got about 8 hours of listening to this over the last 2 days and still love the way it sounds with my Alclair RSM CIEMs! Great clarity bass and very open.
  12. John1122
    I appreciate your advice I'm a newbie at this I really don't understand what's the difference between balanced and unbalanced mainly I just want to use this as an MP3 player for high-resolution audio I don't mind buying a small portable amp or the other module since I don't have Fiji customers mk2 yet I don't know how my headphones would sound with it when I hook up the p7 wireless I think it lacks a lot of bass and I do have a C5 amp I also have Dre Studio when I went to Best Buy do Dre Beats Pros had really good bass but didn't sound as good as the as the p7 I will definitely check out the ones that you recommended I was just wondering if I got an amp a portable app and maybe even that module are there other headphones that would sound better with clean Bass also I really appreciate it if you would explain unbalanced headphones to me thank you
  13. Azirius
    @FiiO I know it’s Christmas so I’m not expecting immediate assistance. I’m still unable to use the Viper Effect side of the Fiio Music player. I’m running the most up-to-date firmware, tried running a factory reset and made sure to have the WiFi turned on when I first turned on Viper Effects. Does not help at all. The built in equalizer doesn’t do anything to either. I’ve tried the HiBy music app also and the equalizer works fine for me. I don’t understand why it isn’t working. I’ve paid for a few of the extra effects and while inexpensive it’s still annoying. I hope no one else is suffering with this issue?
    Just to confirm, it also doesn’t work in either Android or Pure Music modes.
  14. haoyuan
    There is a master switch on the top right, make sure that’s on first before toggling on the bottom switches.
  15. Azirius
    I have indeed toggled this switch. Many times. To no avail. :) Thank you, anyway.
