FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Dec 27, 2017 at 9:29 PM Post #3,496 of 6,207
similar to I, but I tried mojo with the onkyo dps1, not poly
I think the mojo is good too, but the soundstage of x7ii is better
I agree that mojo is good, especially its placement. But, x7ii is better in clarity..
Dec 27, 2017 at 9:43 PM Post #3,498 of 6,207
If you mean where you buy them from, I always buy them from HD Tracks. There are a few others but I only use HD Tracks.
Great. Thanks! hehe
Dec 27, 2017 at 10:34 PM Post #3,499 of 6,207
Dec 28, 2017 at 4:18 AM Post #3,500 of 6,207
I can indeed enter the Viper Effects interface and I can play with the options within, but none of them have a single effect on the music being played. I’ve tried all the options available, purchased a few of them too and they still don’t work. All the toggle switches work perfectly (so, from on to off and off to on), but no change to the sound at all. The same can be said for the equalizer portion of the Fiio Music app.
These facts remain true even after a factory reset.
I definitely made sure the internet was connected upon first using the Viper Effects, too.
Even when using the viper effect--master gat(limiter)--channel pan?
Best regards
Dec 28, 2017 at 4:24 AM Post #3,501 of 6,207
Now a question. I have already bought all the Viper effects for the X7. Do I need to buy them all again or can I reclaim them somehow?
I Bought ViPER Effect on X7, could I use it on X7MKII?
A:We're sorry that ViPER Effect could only support the device which has been paid for. Any new device will have to repay for it. But it would be a problem when you upgrade the firmware. You could rest assured.
Best regards
Dec 28, 2017 at 4:49 AM Post #3,502 of 6,207
Best regards
Thanks for the answer
Dec 28, 2017 at 5:21 AM Post #3,503 of 6,207
Best regards
Hey,
Correct. None of the options within the Viper Effects menu have a single effect on sound output.
Dec 28, 2017 at 11:45 AM Post #3,504 of 6,207
Guyss, may i know where do u guys usually download DSD/ FLAC 24bit files?
I nerver buy DSD or Flac in 24 bits since nothing of my taste can be found in those super exotic formats, but if I'd buy them, I can vouch for HDtracks as an awesome site to get those from.
Also, the new firmware is still going strong on my side! Great job to @FiiO for making an awesome firmware, even so close to the end of 2017
Dec 28, 2017 at 2:56 PM Post #3,505 of 6,207
Dec 28, 2017 at 3:03 PM Post #3,506 of 6,207
After disconnect FiiO X7 from the PC, in order to transfer files, volume wheel not run, need to reset the device.
Dec 28, 2017 at 3:17 PM Post #3,507 of 6,207
will not physically move or moves but not increase or decrease sound level?
Dec 28, 2017 at 3:26 PM Post #3,508 of 6,207
Dec 28, 2017 at 3:27 PM Post #3,509 of 6,207
Dec 28, 2017 at 3:43 PM Post #3,510 of 6,207
