- Jan 30, 2011
Yesterday I met a person who insisted that the same file played from CD and from HDD might sound different, for the same file exactly, so I'm really trying to give everything the option to sound true.
What has that got to do with one digital output sounding better than another? Ever entertain the thought that the person who told you this is clearly wrong? If the file is exactly the same and is being played via the same DAC = how can there be a difference.
Have you ever heard jitter? What does it sound like? I think you need to actually do some research my friend. Jitter hasn't been an issue for at least the last 20 years unless the components have intentionally been designed poorly. I can assure you the X7iis aren't a poor design.I think that, if everything said in all the papers is true, the Digital out should have better clocks or something like that, while the OTG isn't affected by those. I think they were named timers, or anti-jitter, I noticed that a lot of DAPs feature the signal passing through those before going to coaux, while this isn't true for OTG.
So don't make the statement / answer to a query unless you actually know. Otherwise your reply is simply noise. Heaven knows the SNR on the whole forum is bad enough at the best of times.Whether this is audible or not, I still need to test, this is why I went with *probably* there.
Yet you haven't tested it (by your own admission).What I can say though is that the digital out is much more trusty that the OTG out, at least for me.
Looks like it would last better to usage, with the shape of the connectors looking like that, while OTG might place strain on the connector in just one direction, and it might be less resistant to strain. I hadn't had either break on me, but just saying, I like how the co-ax feels much better.
So while that might remain in the *probably* territory, the fact that the connectors shape and reliability is better in the long run, is kinda true.
What does this have to do with this:
I don't have the original X7 on my hand, but I don't think USB OTG for a transport, works, but I am absolutely sure that it works as a transport using its digital out. since it has a dedicated digital out, it will probably sound better than the USB OTG anyways.
