FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
474 475 476 477 478 479 480 481 482 483
485 486 487 488 489 490 491 492 493 494
  1. steamboiled
    Do i need to re-post just to get this noticed? @FiiO
  2. salla45
    thanks for this
  3. sabloke
    Got the replacement for my 3.5mm dead port M11 and it is Pro version (bridge the gap for it). Love the sound, listening on Blon BL-03 on 4.4mm balanced and loving it. Too bad I can't compare with M11 since I don't have one but not complaining :) Will fire up Sony Z1R shortly, too.
    PS: in case you're wondering, the Fiio pleather M11 case is a very snug fit on the Pro, good thing because it stops the case sliding every time you access the ports on the bottom like it is the case with M11.
  4. hldn
    Return it. Sounds like a faulty unit.
  5. Micha111
    Hello,
    I have just registered here but reading on head fi for a long time already.
    I registered because my M11 also has a very poor Standby time. I thought it needed to be powered off to reach its 50 days of Standby. Even then my M11 battery would not last that long.
    With screen off only and no app running in background and even no active connections it would last only some days...
    ZiGFi likes this.
  6. harpo1
    Anyone else notice when you have an external DAC connected to the M11 the volume is extremely low? I've connected my mojo and ifi iDSD and I have to max out their volume to get to a decent listening level. If I hook the up via coax no issues at all with audio volume levels.
  7. jdtenny
    Perhaps your DAC is expecting line-in signal, did you set the audio output to line out?
  8. harpo1
    DAC use a digit input not analog.
  9. SoundChoice
    50 days of standby is marketing magic, and in my experience anything more than a week is a miracle.
  10. omlettes
    Is anybody using a 3rd party music app on their M11? Do you have a minute?
    I'm trying to collect a compatibility list of 3rd party music apps over in this thread (so the information doesn't get lost in this 500 page mega thread). Your comment would help build knowledge that benefits the community and future owners.
    Thanks
  11. Micha111
    I know. But it is like one percent per our. This is not the deep sleep mode the M11 should fell in. Every smartphone I got has battery life in stand by mode.
    Already tried to factory reset the M11 and the common solutions.
    On the other side: Can someone experience a lot better battery life here?
  12. ZiGFi
    Hell
    So, I've checked with WiFi and Bluetooth OFF, all apps closed and I have around 3% battery consumption after 24 hours and 12 days estimation for battery usage. I didn't used the M11 at all in the last day.
    Indeed it's better than before but not as good as advertised.
  13. Darren Cotter
    No reply from FiiO. I'm looking for help here!
  14. hldn
    Get a replacement, the 3.5 it's clearly faulty.
  15. Airsculpture
    Using Poweramp quite happily
    SoundChoice likes this.
