FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
472 473 474 475 476 477 478 479 480 481
483 484 485 486 487 488 489 490 491 492
  1. radarnigz5
    no one? :frowning2:
  2. Stymeron
    I use mine for music, and nothing else. Can't help you. I'd guess many others are the same.
    tr2420 likes this.
  3. salla45
    Try using (at)fiio when posting your issue and fiio should respond, eventually :)
    What software are you using for music on the computer to play via your M11?
  4. oHOWEo
    Did you install the drivers? It's included on a partition of the Fiio but the Fiio website is the best place in case they gave and update
  5. radarnigz5
    yep, installed v4.47 afaik...
  6. radarnigz5
    solved it by resetting and not doing anything on settings after
  7. shinewallace
    Hello my Fiio....
    my email has still not yet been replied for a week....
    Please help... I have already sent the updated log files to you for investigation.
  8. misteral201103
    Question for M11 owners who also have an iPad Pro. Has anyone tried using the M11 as an external DAC/AMP for the '18 iPad Pro? Did you use the M11 as a bluetooth receiver or did you try USB C to USB C?
    Got a trip coming up where there'll be times my wife and I both want to listen to her iPad via earphones, which means physical connection and splitter. Don't really want to shell out for a DAC/AMP just for this, was hoping the M11 might come to the rescue.
    Anyone tried this? What were the results?
  9. kgs51
    I own the FiiO M11 and I am looking to purchase a headphone amp for this. I understand the the Schiit Magni3 is a good amp and gets excellent reviews for its price. Because I am new to headphone amps, I want to know how to hook up the amp to the FiiO M11. Is it compatible even with the the Magni 3. If not what would be a good alternative.
  10. radarnigz5
    Issue persist after reset, its some inteference that sounds like a helicopter ( you read it right )
    Using musicbee
  11. vibin247
    All you need is a 3.5mm stereo to RCA cable to connect the FiiO M11 to the Schiit Magni 3. Use the Line Out function on the FiiO M11, and then adjust the volume on the Magni 3 to taste during playback.
  12. vibin247
    Do you have a bit perfect setup?
    Playing with the playback buffer can sometimes introduce artifacts, especially when trying to achieve a direct connection through ASIO.
  13. spanner43
    I often use the line out from the m11 into a magni3 and sometimes my asguard 2. yes they are compatible.
  14. kgs51
    Thank you very much for this information. I just ordered the 3.5mm to 2-Male RCA Adapter Audio Stereo Cable
    vibin247 likes this.
  15. FiiO
    Dear friend,
    Sorry for the late reply. It took some time for the engineer to check your problem. My colleague have provide a new beta app to you via email. Please have a check.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
