FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
473 474 475 476 477 478 479 480 481 482
484 485 486 487 488 489 490 491 492 493
  1. FiiO
    Dear friend,
    Did you turn off the Bluetooth, Wifi, and the screen is off?
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  2. ZiGFi
    Hello, bluetooth and screen were off. Wifi was on but Keep WLAN on during sleep was set to Only when plugged in. The standby drain is very bad on my device and I already have reset it to factory settings. Should I also disable Wi-Fi?
  3. shinewallace
    Thx a lot, I will try the new version later when off work today.
  4. FiiO
    Dear friend,
    We have reported to the engineer about your feedback. They will try to access the feasibility first.
    Best regards
    salla45 likes this.
  5. FiiO
    Dear friend,
    Would you mind turning off the Wifi and check again?
    Best regards
  6. ZiGFi
    Ok, I’ll do that and come back with feedback.
  7. FiiO
    Dear friend,
    The test.aac file you sent is not standard AAC file so the decoding library could not support it currently, sorry.
    Best regards
  8. Mp0wer
    Does the M11 have a bass boost ? I couldn’t find anything but the EQ
  9. kgs51
    Which port do I use on the M11 to plug the 3.5mm end into.
    RikudouGoku likes this.
  10. x X x
    Really man? There are 3 ports, all with different sizes...
    With screen turned upwards, from the left: 4,4mm / 2,5mm / 3,5mm.
  11. kgs51
    I realized this after I looked at the manual. Sorry for the question.
  12. x X x
    No need to sorry :) There is only one place when you can fit without loose 3,5 jack :wink:
    loungecat likes this.
  13. Darren Cotter
    I've just got my M11, but can't get any sound. I'm using the 3.5mm output and in the audio settings, it's set to PO. Any ideas?
    Edit: The 2.5mm output works fine. No way to test the 4.4mm.
  14. jdtenny
    Suggest you check whatever is on the other (non-M11) end of the 3.5mm cable. Maybe you just need to turn up the volume on that end, or enable input channel selection on the receiving device.
  15. Darren Cotter
    I've tried other IEM's on the 3.5mm and nothing working. It's not connected to an amp or anything . Just using as a standard DAP.
