[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
May 29, 2019 at 9:08 PM Post #1,697 of 9,288
Looks like amazon got their M11 shipments in a bit earlier than normal? Instead of Tuesday delivery it now says Friday!
I can't find the m11 on Amazon :/
May 29, 2019 at 9:10 PM Post #1,698 of 9,288
May 29, 2019 at 9:22 PM Post #1,699 of 9,288
May 30, 2019 at 4:16 AM Post #1,707 of 9,288
I bought M11 at aliexpress in China. it doesn't have installed any tidal and other apps promised. what I should do to get tidal here?
May 30, 2019 at 4:21 AM Post #1,708 of 9,288
You'll find all the apps you need on APKPure.com. Also make sure to install the latest firmware. Once you do you'll have FiiO Applications on the M11, from which you can download Tidal and other apps.
May 30, 2019 at 4:22 AM Post #1,709 of 9,288
Ok, thank you very much)
Great combo by the way)
May 30, 2019 at 4:44 AM Post #1,710 of 9,288
What about on sound quality only?
Thanks
Don't know about M11 but my X7II + AM5 sounds better with HD650/6XX (may be because of higher power output) than with WM1A. But with IEMs 1A is more full bodied which I actually prefer over X7II.
WM1A is my friend's and I keen on lending his 1A when ever I try a new app because each app sounds a little different than other. That's flexibility you have with Android.
