I've bought a new E7 to pair with my Sansa clip. But it seems not to improve the power of output Without E7, I set the volume at 80% to be enough to hear. But with E7, I still must set volume at about 75 ~ 78% (with the maximum volume in E7) to be enough. I'm not deaf, so does my E7 have any problems? Beside that, Fiio has recommended their product to be set at 20 volume by default (
You should have set it the other way, max on clip and use the E7 to control volume. E7 volume control is not fully linear, so it varies the gain from -60dB or so to +5dB. Hence, 0dB (no gain) is right around 80% on E7. Setting max volume on clip also help getting better dynamic too.
