- Oct 31, 2008
not a combo i have treid but i cant imagine it would work well, warm with warm would give you an overly warm sound, unless of course thats what you want
I've been reading stuff on the following:
1. Re0
2. Re-Zero
3. Fischer DBA-02
The RE0 and the E7 obviously work together nicely. But have anyone of you attempted to pair the E7 with RE-Zero? Or the DBA-02? Could anyone tell me how do they compare with each other with the pairing?
Hi Mark,
Great review - thanks.
I am considering buying an AMP/DAC as an upgrade to my setup, but considering whether to get the E7 or the Arrow.
I currently only have IEM (SE530, RE-Zero, UE700) but will soon pull the trigger on some home-cans (most likely Senn HD650).
Do you still have your Shure SE530 and have you tried them with the E7?
And do you have some home cans like the HD650 - or is the E7 not able to power these?
I will be using the AMP/DAC out of my Macbook Pro and iPhone 3GS - with the IEMs mentioned above and a can like HD650, main question is: Is this a good plan - or should I go for the Arrow instead?
i havent treid them, its not really a combo id suggest either given the 530 is warm adding more warmth with the E7, not that it would be bad just not a pairing id naturaly pick. oh and the E7 will happily drive whatever you throw at it, of course beefier amps will drive things better but they will do a nice job for now. it runs my HD600 fine. i do believe i mentioned it could drive them lauder than id ever want in the review.
Hi Mark,
Do me a favour answering my question: My sansa clip (not plus) gives a wam sound, what'll happen if I pair my clip with a Fiio E7? (Plus, I'm using Sennheiser HD238, an on air headphone with quite good lows).
Thanks alot !!!
