FiiO E17 "ALPEN" - First Impression + Final Thought
Jan 26, 2012 at 5:13 PM Post #706 of 6,777
Yes? ...
otherwise, the e17 sounds really great. but this buzzing feature/bug isn't acceptable. battery is now loading about 4 h and isn't full.
Jan 26, 2012 at 5:16 PM Post #707 of 6,777
Yes? ...
i think ur battery ...might be damaged or something. like the full post said. with such a high volume of E17's being sold. the amount of faulty ones also increase in some way shape or form. i am getting them in almost a week. i will se if i can hear anything.
Jan 26, 2012 at 5:47 PM Post #708 of 6,777
what gohanssjm said. none of us received them yet and the people that did are mostly regular head fi'ers
yeah. i will be able to post an impression on regular forums and a copy of one here in about a week. i'll get in about 5 days...5days on head fi is a long time...
Just a bit annoying to see tracking info and random thoughts. You could always create another thread to put filler in.
Jan 26, 2012 at 5:56 PM Post #709 of 6,777
this is the only active E17 thread. makng a new one means u have to start over. this thread is viewed a lot. it's just for discussion about it. why not. The rule of Head-Fi you should get used to. ALL threads get derailed and go off topic in some way shape or form. most get back on...and then off. and the cycle repeats
Jan 26, 2012 at 6:02 PM Post #710 of 6,777
Are you going for "the most posts without the product" record?
Jan 26, 2012 at 6:14 PM Post #713 of 6,777
Guys, we're all just excited about a new product and posting about it.  Nothing to get mad over or to start making little quips at each other over.  It's just text on a screen.
I do agree. if you guys do care. post about it like tim did and if we get enough. we will stop of course..but so far. i dont see any
Jan 26, 2012 at 6:33 PM Post #714 of 6,777
Who's mad again? Just create a new 'excited for e17' thread or something. It's not hard to do. Otherwise you're just flooding thread email subscriptions with useless bits.
Jan 26, 2012 at 6:45 PM Post #715 of 6,777
i don't and i don't think most link this to their emails. most like me just use their notifications..i think
Jan 26, 2012 at 8:17 PM Post #716 of 6,777
@ClieOS:
I remember looking up through the search function and you had a post concerning using it on USB mode with charging turned off. If this effectively bypasses the e17 battery altogether, do you suppose it to still work on USB mode if the batteries die (or with the batteries removed altogether)?
Jan 26, 2012 at 8:19 PM Post #717 of 6,777
@ClieOS i also have a question. it seem the E11 has a high performance mode inside it. near the battery. does the e17 also have this.....i don't think u openeed it..but in case u did. And also. does E11 batter work with this?it seems in micca store it said people that bought E17 also bought E11 battery kit ?
Jan 26, 2012 at 9:43 PM Post #718 of 6,777
There is actually a thread started by Jack-Micca which would be an ideal place for discussing tracking info and such. Just a suggestion :)
http://www.head-fi.org/t/591410/us-availability-for-fiio-e17/30
Jan 26, 2012 at 9:48 PM Post #719 of 6,777
as you can already see...i've been there. not too many people there and it's been dead for a couple of days
Jan 26, 2012 at 9:56 PM Post #720 of 6,777
1, E17 does not includes the switcher to change the supply voltage.
2, Only E11 support replaceable battery.
BTW, thanks to bowei006, you help lots of people in here! :)
