I assume some sarcasm here about the mis-phrasing of 'turning your E17 into a laptop' and not how you configure the E17 to lock at 96KHz 24 bit for playback? But just in case you weren't being sarcastic and really wanted to know how to lock the E17 at 96KHz for playback, here's how you do it:
On a Mac you go into Applications - Utilities - Audio Midi Setup, choose the Fiio E17 from the list of playback devices and then set the output format as 96.000KHz and 2 ch - 24 bit integer.
On a Windows 7 box, open Control Panel, Hardware and Sound, Sound, choose the Playback tab, highlight the Fiio E17 USB DAC device and choose Properties at the bottom of the window. When the Properties dialog open, deselect everything except 96KHz and click Apply and OK. Then when you playback with the Fiio E17 as the selected output device, the E17 should display 96KHz and 24 bit as the sample rate/bit depth on its screen.
Dale
