visanj
- Jul 7, 2011
I got to know from my home that E17 has arrived but I'm in Office now
Can't wait to go home but work is killing me....
Brightness is said to decrease over time . EQ is also an option.
Listen to it for at least a week. Get used to the more audiophile accurate sound and then go to clip direct out. Then make descision on keep or not.
While you are listening ,this is a great article to read up on.
http://www.head-fi.org/t/564465/misconception-of-neutral-accurate
I didnt write down or make mental notes of iniial improvements but all over this thread, decreasing of brightness have been known to happen from others. You can try to adjust an lower treble EQ, treble does have a bit effect on overal brightness, but again the two are different things an artificially modyfiying the treble is only a half butted way of doing it
I tried to reduce treble EQ but I feel as if its ruining the whole strength
Ah, thanks for the info and link. I used my E17 with the 360 today as I got it back and purchased an LED projector. Didn't keep track of time but when I finished gaming, the battery indicator had zero bars, LOL. Is it safe for me to charge/keep it charged with the 360 wile using the optical cable input option?
Totally safe, I use the optical with my desktop while charging it off my mac , so having it plugged in via all 3 ports is totally fine, and if you were using something besides the Xbox 360 as the usb power supplier like a laptop or something then you could also toggle to using it without interrupting the charging.
TLR totally safe
