xxhaxx
- Jul 17, 2010
The adapter for the Little Dot MKIII? Or you're talking for the computer.
Cause I want that amp and that would be great!
No I meant for the E17+ L7 for line out into mkiii
Quote:no, i didn't get it yet of course (dunno when mp4nation will ship)... but now that i have such a great improvement than what i had before using the galaxy s (with wolfson + voodoo) and my maybe 100 hour burned in DT880 250s....... I'm not expecting a huge improvement with the E17... i'm pretty sure I want something that'll improve a TON on what I already have now..... if the E17 can KINDA drive the HD650.........well, I think I want something that can REALLY DRIVE the hd650 and dt880.
not gonna cancel my order yet though.. I'm thinking a used little dot MKIII will be my next acquisition
Pairing E17 with little dot mkiii sounds not a good idea, because E17 is not a pure dac. You should really consider E9, imo.
i know. i'm thinking of getting the mkiii instead of getting the E17 I'm not particularly TOO excited about getting the E17 anymore... I'm sure it'll really improve my laptop/ipad 2 sound, but not so much with my phone.i do most of my listening on my phone for some reason. Consider the E9 for just amp and the setup I have now (phone + dt880?) over getting a mkIII?
So, E17 will give me a little improvement of the sound i have on my phone now...... but I want another HUGE improvement, like I just experienced
(Samsung Nexus S is a phone)
@hyogen - What are you playing on your Nexus? i.e. mp3 or 'phone format' files right? If you like the sound of the DAC in there, but want more drive to your headphones, then an amp is what you're looking for. If you want it portable, that would be a consideration - although you wanna consider that you'll need batteries for the amp if you want to stay mobile. If you allow the E17 to ship and deliver, before selling it I would try to get digital out on the phone if it supports it and compare the DAC on the E17 to that of your phone.
Back to source files - if they're mp3 with moderate bit rate (192 to 320) then adding hardware wouldn't make them sound much better, as I understand it. Anyone back me up on that?
thanks. Hmm...I see. So, an added amp (even something pretty good like the MKIII for around $200) wno't really make it sound much better?
and yes, i'm using mp3 files.
@bowie006 - if he's using a phone to play files on, I doubt he's using lossless. For 192-320 bitrate, which I'm assuming he'll be using from his phone, would going digital out from the phone to a DAC/AMP like the E17 improve the sound much? (He likes the DAC on his phone, and plans to use an amp for the analog out from DAC.)
i don't know if you saw it roadkam but i answered ur question
Quote:thanks. Hmm...I see. So, an added amp (even something pretty good like the MKIII for around $200) wno't really make it sound much better?
That's my theory. I'm trying to get someone more experienced to give an opinion... if your headphones are being driven adequately by the phone, then an amp won't add much besides volume as I understand it. In that case, making sure your headphones ARE being driven well by your phone would be where you'd want to focus.
At this time i believe it would be better for hyogen to maybe instead of spending a couple hundred on amps and DAC's to just upgrade to a higher level easy to drive headphones. teh AHD 2000s are on the top of my lips. but hey it could be anything
I agree. I'm not sure if they ARE being driven to the max. I'm almost positive they aren't....I mean it's a 250ohm headphone. comparable HD650 is just adequately driven by the E17....but again most likely not fully driven. that's what I want....fulllllly driven
these DT880 250ohm aren't high level enough? I think they are... I don't think I've heard these fully driven yet. I've only heard from my phone/wolfson/voodoo control and 5db amp/
It's not about volume at all. I'm getting plenty of volume. like i said above, I just want to FULLY drive these. What you're saying is to get a more expensive headphone that's like 32ohm, right?
