Just listened to two tracks, Alley Cat by Holly Cole and Gone by Melody Gardot, and while the MC5s held their own, they didn't have as "full" a sound as the DBAs. Both sounded excellent, but the DBAs are just a tad more liquid, smoother and,as noted, have a fuller sound. Again, it's the law of diminishing returns. If you have $80 to spend, you can't do much better than the MC5 in my view. But if you have $170, the DBAs are a better IEM (at least based on those two tracks, which are both very clear vocal tracks).
Now, I used custom sleeves on the Etys and Ety tri-flanges on the DBAs, my preferred tip. I also listened via the Touch HP out, bass boost on via EQ. Two excellent IEMs for the price. But I am going to let the MC5s burn in a little today, maybe 24 hours, and see if the bass does change.
Here's the company's 411 on the driver technology (hype alert!, but they are very good):
https://www.etymotic.com/aer/press/ER_PRESS_RELEASE__mcSeries.pdf
Etymotic’s patent-pending response-shaping ACCU•Chamber process corrects known limitations of lower-cost moving coil (dynamic) drivers, which have dominated the market for replacement earphones. Prior to the release of the MC Series, listening to music with these traditional low-cost products usually meant suffering through sloppy bass and overly bright or very dull mid- and high-frequency detail. The result was a great deal of listening fatigue and a disappointing musical experience.
Etymotic’s breakthrough technology uses an Acoustic Control Chamber (ACC) placed within the moving-coil structure that acts like a three-band equalizer. This process of acoustic sound shaping achieves the highest sound accuracy in its class. The ACC consists of a resonant control gate, an acoustic side branch and two acoustic dampers that smooth the undesirable response peaks and compensate for the weak high-frequency response of standard dynamic drivers.
Dr. Killion and his Etymotic Research engineers have combined the ACCU•Chamber driver housing with a specially designed high-output 8 mm neodymium moving coil driver that achieves a 3 dB increase in sensitivity over the normal 8 mm drivers on the market. This approach allows use of a smaller driver for a more compact size, which better fits ears of all sizes and shapes – without sacrificing sound output. As a result, MC-Series users listen in comfort with less ear fatigue than users of ear buds and other types of earphones.
