For those who are waiting for AMP4,5. There will be official announcement next week. Also, there would be a 11/11 event (probably a discount or promotion)
Discovered this after removing the leather case (it's been on the unit since I received it. only removed when taking out SD card). Also the SD card won't come out if I push it for release.
Lurker, I use neutron with direct USB driver. Every time I turn the screen on USB Audio Driver displays "Screen is interactive, restarting...". Is that really required?
Such a problem first was reported by @Jumoonji. It took me almost a month to realize that there are more than one VID/PID pairs for DX200 in USB DAC mode, while I thought there is only one. USB Audio waits for a particular VID/PID device attached, and does not see it. I've PMed you with a test build of 2.5.141L2, which addresses this problem. Please continue further discussion in PM.
I just received my Amp3 today but I am not sure if this is normal as it does not happen on Amp1.
Every time I power up the DX200 with Amp3, the both left/right channels have a loud static noise but the left side is louder.
However, once I started playing music and stopped, the static noise goes away. It remains this way until I power-down but the static noise reappears when the DX200 is power-up again.
The loud static appears when DX200 starts up in both Android and Mango mode, only goes away when I started playing.
I am on version 2.3.125 of the firmware. Will install the v2.5 and report back.
You can see attached a photo that shows it's back panel connection. For the output it has on the front only one 6,5mm output for the headphones.
My question is - looking at its back panel - what is your suggetion of "how to" connect the dx200 with it ? The heaphones could be HE-560 (for what I have both balanced and unbalanced cables) and Noble K10 unbalanced.
I have both AMP1 and AMP3 so I'm able to "Line out" from Dx200 both in unbalanced and balanced mode.
Do I have to follow a comple unbalanced path (since the PATHOS headphones output is unbalanced) or does it makes sense to enter in PATHOS through AMP3 ( so a sort of hybrid path: dx200+AMP3 lineout balanced into PATHOS and from PATHOS to headphones through unbalanced)
