DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
post-13798038
Post #9,541 of 21,843
twister6
twister6 Reviews
Website
twister6.com
From my experience, cables longer than 1m will not work with DX200. The problem, as I understand, is that, internally, USB interface is connected via a switch between the SOC and XMOS chip, to implement USB DAC mode, in which XMOS chip takes over the USB connection. This switch has a negative impact leading to the restriction to the cable length.
Yep, with usb-c the support is <2m cables with gen 1 and <1m with gen 2, and there has to be correctly programmed ID chip indicating the protocol, etc. I would suggest staying within 1m cable length and buy it from reputable 3rd party sources, if you need an extra cable besides the one provided by iBasso.
post-13798161
Post #9,542 of 21,843
chaiyuta
Bangkok, Thailand
Bangkok, Thailand
Website
fb.com
2 months passed. Finally, My DX200 come back home. Seamless AMP module through Player. Responsive touchscreen. Happy listening.:L3000:
post-13798162
Post #9,543 of 21,843
jerick70
Utah, USA
Utah, USA
post-13798256
Post #9,544 of 21,843
Morimoriya 62
IRAN Tehran
IRAN Tehran
Congratulations :)
Reactions: Glasha and chaiyuta
post-13798413
Post #9,545 of 21,843
Vishal
How much of an upgrade is dx200 to that of aune m1s?
post-13798439
Post #9,546 of 21,843
icefalkon
NYC, NY
NYC, NY
The Aune isn't even close to the sound quality of the DX200. Plus the interface is miles better. You're talking about a flagship DAP vs...well...not a flagship DAP...if that makes sense...lol
Reactions: chaiyuta
post-13798441
Post #9,547 of 21,843
jerick70
Utah, USA
Utah, USA
I've not heard the Aune m1s, but many think of the DX200 as the best of the best when it comes to TOTL DAPS. I highly recommend the DX200.
post-13798470
Post #9,548 of 21,843
chaiyuta
Bangkok, Thailand
Bangkok, Thailand
Website
fb.com
Lucky enough that nobody come to ask how about DX200 vs Walnut V3 or Zishan V2. lol
post-13798492
Post #9,549 of 21,843
Vishal
Aune m1s balanced is not bad and by the way how much of an upgrade dx200 is in terms of sq.? This was just to increase my excitement.
post-13798519
Post #9,550 of 21,843
meomap
California
California
Hi,
Need your help.
DX200 used to connected and used as usb dac.
Some how did not work anymore even though reset both DX200 and mbp.
CDM used as dac ok.
Thinking cable provided used as 2 functions as dac and charge.
This morning I checked DX200 and see it did not charge anymore. Tried multiple usb holes and did not see charging symbol on DX200 anymore.
Assume cable is completely dead at this point.
You know if Paul from iBasso taking care of this as warranty issue?
Does Best Buy have the usb c cable with 2 functions or amazon store only?
Needed for today. Have only 40 % juice left.
Any advice?
Thanks.
post-13798532
Post #9,551 of 21,843
jerick70
Utah, USA
Utah, USA
Hi,
Need your help.
CDM used as dac ok.
Any advice?
Thanks.
It could be the USB cable or the DX200 itself. Have you tried the cable on another device beside the DX200? You will have to talk with Paul on the warranty. Also most usb type c cable will work with the DX200. Best Buy cables should work.
post-13798576
Post #9,552 of 21,843
chaiyuta
Bangkok, Thailand
Bangkok, Thailand
Website
fb.com
post-13798630
Post #9,553 of 21,843
meomap
California
California
Thanks. Just grabbed one from Best Buy.
I don't have any new item to use with usb c . DX200 is the first one.
Wait for tonight after work then teat it.
post-13798754
Post #9,554 of 21,843
mikeral
Lurker, I use neutron with direct USB driver. Every time I turn the screen on USB Audio Driver displays "Screen is interactive, restarting...". Is that really required? The music stops and then restarts in a moment, but not always, often i have to reboot the device in order to connect neutron to USB Audio again
post-13799469
Post #9,555 of 21,843
artpiggo
Bangkok, Thailand
Bangkok, Thailand
For those who are waiting for AMP4,5. There will be official announcement next week. Also, there would be a 11/11 event (probably a discount or promotion)
Reactions: R0blo
