salavat
- Jan 10, 2010
I just got a set of JH Audio Angies and I have to say these are FANTASTIC with the DX200 using AMP2. No joke.
Try then AMP3 )) You might get even more excited)))
Lurker0, it is running 2.5.141L1 and all the settings are as per the post.First, check that you are running 2.5.141L2. Then, check your settings against this post to be sure that Neutron does not destroy DoP stream.
I am with you on this oneI heard that amp4 is coming soon. That was weeks/months ago.
Just trying to understand the definition of "soon".
Are we a few weeks away or few months?
Anyone has more details?
Can't wait to try it.
Thanks
Has anyone being able to successfully connect the DX-200 with a 2m USB-C male to to USB-C male cable? I've purchased such a cable which was advertised as as being compliant with USB 3.1 Gen 2 SuperSpeed etc etc. However it will only charge the DX200. I cannot get the DX-200 to prompt the USB mode to select file transfer.
From my experience, cables longer than 1m will not work with DX200. The problem, as I understand, is that, internally, USB interface is connected via a switch between the SOC and XMOS chip, to implement USB DAC mode, in which XMOS chip takes over the USB connection. This switch has a negative impact leading to the restriction to the cable length.Has anyone being able to successfully connect the DX-200 with a 2m USB-C male to to USB-C male cable?
No, nothing special. Don't mess with Apple devices!USB type C is special, it needs authentication chip on the cables ends, and the device itself.
Scroll to far right screen.
Settings/Advanced/android
