DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
624 625 626 627 628 629 630 631 632 633
635 636 637 638 639 640 641 642 643 644
  1. KEV G
    Will do, can’t wait to hear the Andromeda with the Amp 3 . Thanks Jae
    JaeYoon likes this.
  2. Signal2Noise
    Paul has mentioned in this thread previously that there were no plans to. However, things do change and maybe iBasso will have a change of heart.
    KEV G likes this.
  3. tuckers
    What is the connector for balanced output of the DX200 and what is the soldering guide for terminating it? Thanks
  4. HiFlight
    iBasso uses the same 2.5mm TRRS wiring as does A-K: Tip=R-, Ring 1=R+, Ring 2=L+ and Sleeve=L-
    Unfortunately, there is not yet a standard used by all manufacturers for balanced connectors.
  5. musicday
    Still waiting for news about the copper and titanium versions.:frowning2:
    Paul don't let us down.
    Morimoriya 62 and Glasha like this.
  6. Morimoriya 62
    What do you looking for ? DX200 with Amp3 excellent :wink: I enjoy it every day
  7. Reima
    Hi Paul, any news on the AMP4?
  8. musicday
    Well i prefer the look of gold plated copper:)
    Morimoriya 62 likes this.
  9. artpiggo
    If you are rush, try go to university lab. There should be Chem Sci guys who can do anodizing surface for your dx200. :kissing_heart:
    mrmoto050 likes this.
  10. BLmusic
    I follow all the above settings but not able to play DSD files, please advise what did I missed out. Thanks Burt
  11. Paul - iBasso
    It is right around the corner.
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
    Dobrescu George likes this.
  12. cbeaumont001
    I have a few troubleshooting questions to help figure this out:
    1. What firmware version are you using? Stock or Lurker0 modified?
    2. What version of Neutron are you using?
    3. What type of DSD file are you trying to play? DSD64, DSD128, etc. I need to know the sample rate.
    4. What happens when you try to play the file? Do you get white noise or does playback not even start?
  13. KEV G
    2AA9A860-E524-4B8E-87A3-3E7C226EDE78.jpeg I am now the proud owner of the infamous Ibasso screwdriver :ksc75smile: and also the fine Amp 3 that came with it. Having a last listen to my old friend Amp 1, before its retired to the Amp 3 box and I think I may be in for another late night of “just one more track” :L3000:
    fuhransahis, Glasha and mrmoto050 like this.
  14. musicday
    Finally in your hands in UK now. Congratulations.
    Soon you will place two more orders, AMP4 and AMP5 :)
    Glasha and KEV G like this.
  15. tuckers
    Here's a dumb question, as I haven't made a balanced cable before, Is there no ground connection to the iBasso with this plug? I thought all balanced circuits required a separate ground?
